M + M Design
3D object coordinates, how to locate on plain??
What is the best procedure for determining the coordinates of a 3D object in a 3D environment. I want to move a 3D object to another place numerically. I have a ground plain X-Y-Z and I have set up a working plain, I-J-K
If you have snap to objects on, when the cursor is snapped to a 3D point the coordinates appear at the top of your screen. Or, you could put a 3D locus at the desired vertex and read off the coordinates in the info palette. With the second method, you can choose whether to see coordinates in X,Y,Z or I,J,K system.
[This message has been edited by P Retondo (edited 07-02-2001).]
This sounds like a problem I had a while back that I solved with a script tool. You select the 3D object you want to move, along with a 3D point, and you type in the x, y, and z coordinates you want to go *to* in a dialog. The 3D point serves to give VW coordinates to reference from.
BTW, if you work in 3D much at all, you really do need a tool like this; just moving via relative position isn't enough.
I would be willing to give it to you if Nemetschek doesn't think there's anything wrong with the approach I took with this; I created it out of desperation. If anyone from Nemetschek reads this, would you be willing to look at the script if I sent it to you to evaluate?
Michael B. Moore
Owens Cross Roads AL
