Mike R Posted May 21, 2009 Share Posted May 21, 2009 Say you have a 3D shape of some sort. Think of its 2D surface area. Is there a way that you can determine the size/pattern of a flat sheet that would be necessary to "form" this 3D shape's surface? For example, if you have a 3D cube, you can imagine it being made up of a flat "+" shape that is then folded up to form the surface area of the cube (plus an extra square for the "top"). Is there a possible tool to figure out this in Vectorworks for more complicated 3D objects? Thanks in advance for any help, Mike Quote Link to comment
Ray Libby Posted May 21, 2009 Share Posted May 21, 2009 Vectorworks 2009 has an unfold feature. Please create a signature with your version of Vectorworks and computer specs including OS. Quote Link to comment
Mike R Posted May 21, 2009 Author Share Posted May 21, 2009 Alright, now you can see my weak specs. Anything for non-2009 users? Quote Link to comment
Jonathan Pickup Posted May 22, 2009 Share Posted May 22, 2009 have you looked at touchCAD? http://www.touchcad.com/ Quote Link to comment
Oyvind Posted May 22, 2009 Share Posted May 22, 2009 Or Revcad Revcad unfold software Quote Link to comment
rDesign Posted May 22, 2009 Share Posted May 22, 2009 You could try Bob Wagner's free 'Unfold' plug-in which works on v.12 and above; it's available at the following link Vectorwiki - Geometry Plug-ins Some other threads on this same topic, which all refer back to Bob Wagner's 'Unfold': Unfolding - again Unfold 3d objects flattening cone section Hope that helps. Regards, Tim Quote Link to comment
JeffPPI Posted May 28, 2009 Share Posted May 28, 2009 Bob's unfold is neat. I used it to make a CNC program for a 8' diameter 4' high crown for PBS's Camelot special. Quote Link to comment
bcd Posted June 3, 2009 Share Posted June 3, 2009 Assuming your 3d object is planar have you tried extract surface? Also if it's cylindrical /conical you may have success extracting the top & bottom curve and using these to draw the developed surface. Quote Link to comment
