angelo Posted June 27, 2001 Share Posted June 27, 2001 I see there has been discussion of VW being a memory hog in the PC platform. Has anybody had problems with VW 8.0.1 & 8.5.2 taking an enormous amount of memory, even more than it was allocated, on a Mac? We are using a PowerMac G3/266Mhz w/ Mac OS 9.0.4. Do polylines such as site contours dramatically affect memory usage and overall performance? What other things might be causing any memory issues? Quote Link to comment
Guest Posted June 28, 2001 Share Posted June 28, 2001 quote: Originally posted by angelo: Has anybody had problems with VW 8.0.1 & 8.5.2 taking an enormous amount of memory, even more than it was allocated, on a Mac? In VectorWorks 8, rendering can use a lot of memory outside that which has been allocated to VectorWorks. My understanding is that this is no longer the case in VectorWorks 9: in VW9, rendering is done in the VectorWorks application's memory. Quote Link to comment
Donald Wardlaw Posted June 28, 2001 Share Posted June 28, 2001 I don't use VW/RW for rendering, I use formz. However, rendering, regardless of the software you use requires a lot of memory. Typically the size of the image you can render, i.e. the number of pixels you can generate, is proportional to the amount of ram you have. I have found that to get decent sized images I need at least 500 mb of ram on a machine. The more the merrier. Ram has never been cheaper. Genuine Fractals, the photoshop plug in is also a reasonably useful tool for scaling up images if the available ram does not allow a large enough image to be rendered. Best, Donald Quote Link to comment
ajs Posted June 28, 2001 Share Posted June 28, 2001 So, then Mr. Wardlaw- Does this mean that you export VW to formZ? If so, may I ask what you like about that approach, and how you do it? -ajs Quote Link to comment
angelo Posted June 28, 2001 Author Share Posted June 28, 2001 Thank you all for your replies and discussion. However, we typically render with formZ instead of Vectorworks. I was wondering whether 2-D drawings had ever sucked memory dry and what people did about that. Thanks for your input. Quote Link to comment
Donald Wardlaw Posted June 30, 2001 Share Posted June 30, 2001 <<Does this mean that you export VW to formZ? If so, may I ask what you like about that approach, and how you do it?>> I prefer to model and render in formz. I prefer VW for 2D, even though formz has a drafting component. I export plan drawings from VW via either dxf or dwg. It is problem free. Once the plan info is in formz, I use it as a guage on which to build the model. Often I take rendered images from formz and import them back into VW, using VW as a form of page layout software. Thus I might have a plan and some 3d images on a sheet with my standard border and title information. This makes for really large files though, one VW file I did recently hit 220 megs. Best, Donald Quote Link to comment
