renderworks problems
Good day Kelly19
How do you mean twice? by itself, or when you export does it Render once and then Save the render?
In the case of option B here. When you want to Export, select the render tipe you want, it will start to render, hold down Esc key. Render will stop. Select the Export tipe you wish.
Please add your system details (OS and VW??) into your signature.
It may associated with the auto save feature where as soon as a rendering is finished the system performs an auto save requiring a screen refresh at the end of the auto save which starts the whole process over again.
Doesn't SHIFT->ESC kill the render process?
To see if this is the issue, try changing the auto save to a longer period of time or a larger amount of steps (or switch it off) ....see if it still happens then....
