Keith W Posted May 18, 2009 Share Posted May 18, 2009 I've created a new title block, which I've used on one sheet, filling in the appropriate values in the "edit title block" dialog, and leaving the "apply these values to all title blocks" checked. When I add a border/title block to another sheet, it asks me if I want to replace it (the title block symbol definition), rename it, or not import it. Then it doesn't utilize the content from the prior title block. What am I doing wrong? K Quote Link to comment
Keith W Posted May 18, 2009 Author Share Posted May 18, 2009 To be clear: I added a new border to the new sheet, and then added the title block to the border. It was just the more obvious way to do it at that moment. Why wouldn't that work? K Quote Link to comment
islandmon Posted May 19, 2009 Share Posted May 19, 2009 TitleBlock uses a Symbol with an attached Record which contains the various Fields. So if you want the same info you will need to use the same Record. Otherwise a new TitleBlock is created with an attached Record with empty Field values. Quote Link to comment
Keith W Posted May 20, 2009 Author Share Posted May 20, 2009 Okay, I think I understood that though not in so many words. But how do I get the titleblock to use the same record? Can the new titleblock be "pointed" to the existing record, or do I need to create the title block/border in a different manner (dragged from RP/Symbols for example?) Keith Quote Link to comment
