Keith W Posted May 14, 2009 Share Posted May 14, 2009 I really like the z-zoom option, it's an easy way to fine-tune my snapping. But sometimes it doesn't "take", and I can't figure out why. It mostly seems to have to do with snapping dimensions, but that may just be when I notice it. What happens is, I "z" in to my snap point, click, and the zoom window disappears as if the click was registered, but nothing is selected. Any reason why that would happen? If I click on exactly the same spot (albeit less accurately) without the zoom, it works fine. Keith Quote Link to comment
Ride Posted May 14, 2009 Share Posted May 14, 2009 Mine does the same thing. I can't generally start a dimension with the snap loupe, only finish one, or continue a chain dimension. Quote Link to comment
ionw Posted May 14, 2009 Share Posted May 14, 2009 I have seen this problem too. A quick work around seems to be drawing a disposable version of what you are trying to create without using the snap loupe. Then when you use the snap loupe to initiate geometry it seems to work. It seems that some form of view change prior to trying to use the snap loupe for creation causes this failure. HTH, Ion Quote Link to comment
