J. Wallace Posted May 10, 2009 Share Posted May 10, 2009 Not sure why or how it happened but all my plants disappeared from a design layer on a completed design. Some loci remained which when highlighted appeared to have the 2d rendering turned off. So I was able to restore a few plants but have lost many....all classes and layer visible. Any thoughts ????? Quote Link to comment
Ray Libby Posted May 10, 2009 Share Posted May 10, 2009 You should list your version of Vectorworks and computer specs including OS. Create a signature with this info by clicking on the My Stuff link at the top, Edit Profile. If a symbol is deleted in the resource browser and an instance of the symbol is in the drawing, a 3D locus will remain in it's place. If it this isn't the case it's more than likely a class issue. Double check your class visibilities. Quote Link to comment
J. Wallace Posted May 10, 2009 Author Share Posted May 10, 2009 Thanks for the tip....I checked the resource browser and all the symbols are still within the file. All classes and layers appear to be visible....not sure why these plant symbols switched off 2d rendering??? Quote Link to comment
Ray Libby Posted May 10, 2009 Share Posted May 10, 2009 Still needing your version of VW for troubleshooting. Quote Link to comment
J. Wallace Posted May 10, 2009 Author Share Posted May 10, 2009 Here's my updated signature... Quote Link to comment
Ray Libby Posted May 10, 2009 Share Posted May 10, 2009 Thanks, could you post the file here or email it to me? Quote Link to comment
J. Wallace Posted May 10, 2009 Author Share Posted May 10, 2009 (edited) The file is 6.3 mg, I can't post this. Not sure how to e-mail this to you ???? I don''t see an e-mail address ???? Edited May 10, 2009 by Jamie Wallace Quote Link to comment
Ray Libby Posted May 10, 2009 Share Posted May 10, 2009 I sent you a private message with my email. If you compress the file (zip) it should be much smaller. Quote Link to comment
Ray Libby Posted May 10, 2009 Share Posted May 10, 2009 Is the problem 2D or 3D? Quote Link to comment
Ray Libby Posted May 10, 2009 Share Posted May 10, 2009 OK, I think I see what you are talking about, the plants in the upper right of the drawing show two lines crossing but no plant. I'm not sure what's going on, but when I right click on any of the plants and choose Edit, choosing any of the choices under Select part to edit:, then exit edit mode, all instance of the plant graphics return. Quote Link to comment
J. Wallace Posted May 10, 2009 Author Share Posted May 10, 2009 An other strange thing is the fact that most of the plants that were in place are no longer visible with the 3d loci. Quote Link to comment
Ray Libby Posted May 10, 2009 Share Posted May 10, 2009 I don't understand what you mean by this. Quote Link to comment
J. Wallace Posted May 10, 2009 Author Share Posted May 10, 2009 A few of the plants which disappeared have a loci to represent them. Most however do not have anything.....Does that make sense? Quote Link to comment
Ray Libby Posted May 10, 2009 Share Posted May 10, 2009 Which plant names disappeared with no marker? With the loci, are you talking about in 2D? If so those aren't loci, they are a two lines crossed to represent the plant position. In 3D, plants have a 3D locus to represent the plant position until you add a plant from the xfrog library Quote Link to comment
J. Wallace Posted May 10, 2009 Author Share Posted May 10, 2009 These plant symbols did come from the xfrog plant library. I would place one tag per group of plants rather than a tag on every plant. The original sheet-landscape layer had a plant list which seems to be missing. I'm really puzzled as to what happened. I have put together several drawing with this version (2009) without incident. I really appreciate all your help. Quote Link to comment
olly Posted May 18, 2009 Share Posted May 18, 2009 I experience the same problem with the 2d plants objects from the 'VectorWorks Landmark 2008 Generic Plant Library'... the only way to show the plants that have disappeared seems to insert each symbol again, and edit them, and they ll will show up again, I can't find explanations to this. If anybody can help .. thx Quote Link to comment
Ozzie Posted May 18, 2009 Share Posted May 18, 2009 Okies - when a plant or plants dissapear find the plant in the Resource Browser - go to Edit or Right Click the Plant and Edit - is the Plant geometry centred at X = 0 and y = 0 when in Edit Plant to find out where the geometry is Select All and fit to objects Let me know Quote Link to comment
J. Wallace Posted May 18, 2009 Author Share Posted May 18, 2009 Discovered something interesting. I followed Ozzie's advice, in the resource browser I right clicked the plant symbol, under edit choose definition, under rendering choose turn on rendering at creation. The plant symbols reappears...Thanks Ozzie it's great to see my drawing was not lost. Quote Link to comment
Marietta Posted May 19, 2009 Share Posted May 19, 2009 I have had something similar. Sometimes, the plants do not show up, but the symbol is still there and all classes showing. What I have done is to open the symbol (editing the symbol), check to make sure it shows up, close the symbol, and then for some reason everything shows up. This gets a bit frustrating. It seems to happen more often if you have imported a plant from a previous version. Quote Link to comment
NPK Posted June 2, 2011 Share Posted June 2, 2011 I'm having this issue on almost every plan I do. It's happening on both mac and windows. Editing the definition to apply 2d rendering on creation helps get them back, but it's not a permanent solution to the problem. It's very annoying, especially when my client calls me to say that there are plants not shown and they want it fixed and reprinted. Is there a permanent fix for this problem yet???? Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted June 2, 2011 Vectorworks, Inc Employee Share Posted June 2, 2011 Check the following: 1) THe None Class is not turned off - even if you have not used the None class for your planting, turning None off will cause your plants to disappear. 2) Check to see if you have Turn on Rendering at Creation within the plant definition. If you do, make sure it is not set to None on the number of outlines. 3) Do NOT check Mass Overlapping Plants - this will hide everything within the plant symbol except for the rear-most polygon. If your plant is a single polygon with a pen outline, there is a danger you could lose it with rendering turned on. You are welcome to email the file to support@vectorworks-training.co.uk if you need me to look at it. You could even make a smaller file - just containing the plants that disappear and I'll take a look at them. Quote Link to comment
Ozzie Posted June 2, 2011 Share Posted June 2, 2011 I'm having this issue on almost every plan I do. It's happening on both mac and windows. Editing the definition to apply 2d rendering on creation helps get them back, but it's not a permanent solution to the problem. There is a bug still present in VW 2010 that will make plants disappear Quote Link to comment
David Kurita-May Posted September 4, 2011 Share Posted September 4, 2011 Hi I have had this problem. Try the following. Double click on the Plant Group or edit from the Resource Browser. Choose to Edit the 2D graphic Select the graphic (circle or similar) and check the Object Info. Most likely the shape is being drawn in Layer Plane. Change this to Screen Plane and use the exit button to return to the drawing. 2D plant graphics should re-appear for any instances of the plant already placed and for any new ones subsequently placed from the Resource Browser. Hope that helps. David Kurita-May Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted September 4, 2011 Vectorworks, Inc Employee Share Posted September 4, 2011 I still believe this to be the None class turned off... Please send me a sample of the plants that are disappearing and I will be able to confirm. Quote Link to comment
Ozzie Posted September 4, 2011 Share Posted September 4, 2011 David, what version of VW are you using? Quote Link to comment
