michaelcobb Posted June 22, 2001 Share Posted June 22, 2001 Is there any way to join two polylines in VW .5.2? Quote Link to comment
P Retondo Posted June 23, 2001 Share Posted June 23, 2001 This may not be the best possible technique, but you can close each polyline using the checkbox in the info dialog box, add vertices if necessary to make the two intersect, then use the add surface tool to combine them into one surface. Turn off visibility of sides you don't want using the 2D reshape tool. (I assume that you meant to say you're using 8.5.2) [This message has been edited by P Retondo (edited 06-23-2001).] Quote Link to comment
