Gytis Posted May 7, 2009 Share Posted May 7, 2009 Trying to track down this inconsistent behavior, and wonder if anyone else has been similarly stumped. Absolutely, positively NOT a class visibilty setting: e.g., I duplicate a section VP which displays correctly and the copy DOES NOT display correctly. All within one file, no WGR or DLVP to external files. Some SVP OK, some not, restart, different pattern. Only pattern I've noticed is (I think) symptom appears with larger files around 100MB or more. Perhaps file corruption...? Quote Link to comment
Guest Wes Gardner Posted May 7, 2009 Share Posted May 7, 2009 I assume the check box "Show Wall Components" under the Display tab in the Advanced Section Properties of the OIP for that section has been checked... Quote Link to comment
Dieter @ DWorks Posted May 7, 2009 Share Posted May 7, 2009 I also had this once, with a new section viewport. I found no solution to it, but would like to here if others found one, if I ran to it again. Quote Link to comment
Gytis Posted May 7, 2009 Author Share Posted May 7, 2009 Thanks for the validation--I don't feel quite so frustrated. Quote Link to comment
Gytis Posted June 2, 2009 Author Share Posted June 2, 2009 As a continuation of this thread, I also run into an intermittent issue with wall component hatches only showing up in walls which run on one axis (sometimes X, sometimes Y) but not the other. Image attached. Any advice? [img:left]http://img34.imageshack.us/img34/322/wallgrab.png[/img] Quote Link to comment
