CARMELHILL2 Posted June 21, 2001 Share Posted June 21, 2001 When using th keyboard shortcuts is it possible to have the programming moidified so the program will not zoom into the middle of the screen (because then you have to pan to the area you were working) but for the program to actually zoom into the area where your mouse is pointing. THis is a nice feature of autocad 2000's zoom. It uses the center scroll button on the mouse to zoom in and out on the screen to where ever the mouse is pointing. Quote Link to comment
Speedy Gonzales Posted June 21, 2001 Share Posted June 21, 2001 Select any object in or near the area you want to zoom in on and ZOOM! Works similarly to AutoCAD's. If you like using a multi-button mouse with scroll wheel (I use MS Intellimouse Optical USB), then you can program the software through the control panel to use the mouse wheel button to zoom in by increments. Not as smooth as AutoCAD, but swift! Quote Link to comment
