HP Sauce Posted May 5, 2009 Share Posted May 5, 2009 How on earth can I join the walls as noted in the attached drawing? Component Join will do the furring and gyp, but for the life of me i can't get all the CMU together. I must be stupid. Any help appreciated. Quote Link to comment
J Lucas Posted May 5, 2009 Share Posted May 5, 2009 Use the "T" join mode. I just tried it on your file and it worked. Quote Link to comment
mike m oz Posted May 5, 2009 Share Posted May 5, 2009 Step 1: Undo the existing wall joins using the Remove Wall Breaks tool, and then stretch the walls back from the connection point (see first image). Step 2: Use the L mode of the Wall Join tool to join the two common wall types (see second image). Step 3: Use the T mode of the Wall Join tool to join the bottom vertical wall to the horizontal wall (see third image). Note: Stretching the walls back from each other is often crucial to getting correct joins after you have removed previous wall joins. Quote Link to comment
HP Sauce Posted May 5, 2009 Author Share Posted May 5, 2009 You are a legend and a scholar. Thank you. Quote Link to comment
