HOUCAD Posted April 29, 2009 Share Posted April 29, 2009 Is there a way to add more divisions to the curtain wall tool? There are only 3 mullion levels and I need 5. I would rather create the whole window wall as one element rather than separate elements by floor. Quote Link to comment
islandmon Posted April 29, 2009 Share Posted April 29, 2009 Consider the fabricator & installer requirements. The design and sectional fabrication should match the limitations imposed by transportation & installation. Quote Link to comment
HOUCAD Posted April 29, 2009 Author Share Posted April 29, 2009 Well, the window wall is 40 feet high divided into 10' and 5' high sections that match precast panels on either side. It fills a 3 story hole in the wall. The biggest piece of material will only be 10' but I should be able to make it one element. The existing panel joints and mullions do not join at the floor levels. I could do it in 2 pieces if I have to but I was just wondering why you are limited to 4 panes of glass with the window wall tool. Quote Link to comment
mike m oz Posted April 29, 2009 Share Posted April 29, 2009 Given the limitations of the existing tool you will probably be better off modelling this manually, and then creating a hybrid symbol of it. - Create three new Classes: WW Framing, WW Glazing amd WW 2D so you can control their appearance. - Switch to the WW Framing Class and in an elevation view draw the framing. - Switch to the WW Glazing Class and use the 2D Reshape tool in 'Paintbucket mode to create the glass. - Select all of the glass polygons and convert them to 3D Polygons. - Select all of the framing and then extrude this by the required depth. - Switch to Top/Plan View. Select the 'glass and move it so it is in the required plan position relative to the framing. - Switch to the WW 2D Class and draw the required 2D 'Plan' appearance directly over the top of the 3D parts. - Select all of the parts (both 2D and 3D) and Create a Symbol of it. Not as convenient as a PIO would be but it can be done fairly quickly. The only issue is if you need to make changes. Then you will have to repeat the process and make a new hybrid symbo.l Quote Link to comment
HOUCAD Posted April 30, 2009 Author Share Posted April 30, 2009 I wound up creating it in several sections and joining them together because of the way the glass is divided. This tool just can't do what I wanted. Now the next question is about the glazing. There are 3 glazing options but 2 show no glass and one makes the glazing and mullions all gray. The same thing with the windows. Do I have to have the renderworks package to make glass look something like glass? Right now my model is all monotone in openGL. Can I at least make the glass a different color for some contrast? Quote Link to comment
mike m oz Posted April 30, 2009 Share Posted April 30, 2009 David, you do need Renderworks to get 'glass' that looks like glass - ie having transparency and reflectivity. Without it you are limited to having either a solid colour for the glass or nothing. You control the appearance of the glass by setting the fill of the Style-Glazing x Class. Use the Container Class at the top of the OIP to control the appearance of the framing. There is a problem with the latter though - whatever colour fill you use for the framing will become the 2D fill in Top/Plan view. That along with the other problems that this object has make it not very useful, which is why I suggested making your own window wall manually. The advantage of doing that is you can include doors and the like in the 'window wall'. Quote Link to comment
HOUCAD Posted May 1, 2009 Author Share Posted May 1, 2009 (edited) Ahh thanks! I didn't notice that it created classes for the glazing styles. With window objects it is a little different but I guess I set the glazing component style and it makes a style# class? This will work great for what I need right now. I am trying to get the bosses to buy renderworks for me but this works for a basic model. Thanks. Edited May 1, 2009 by HOUCAD Quote Link to comment
