Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
HP Sauce
Exported DWGs: No Copy/Paste?!
If we export our drawings to ACAD DWG 02 format the elements are visible and can be manipulated in the exported drawing, but not copy/pasted into a new drawing. Bit annoying.
What have we missed?
Edited by highpass
15 answers to this question
Ah, sorry.. Monday morning and all that...
We export the drawing from VW 09 to ACAD 02 DWG. We then open the exported drawing in ACAD to test it.
Whilst then in ACAD, it is not possible to copy anything from the exported drawing into a new ACAD drawing. Upon pasting, the ACAD command bar shows "_pasteclip", yet there is nothing pasted (or at least, visible).
After reading up on the links you provided it seems inserting the drawing as a block then exploding it fixes the problem.
Any idea what might cause this? I really need to get this figured out before sending our first batch of VW stuff off to engineers.
Cheers for the links!
Update: No problem at all opening and editing the file natively in ACAD 09. Problem only occurs in '02.
Edited by highpass
Indeed, but it only occurs in drawings exported from VW for us. Half our office still uses ACAD 02 daily and we've not seen this before.
It sounds like AutoCad is not loading "pasteclip" by default. You might try turning off "demand loading" in Autocad (if you can). Current computers should have more than enough RAM to handle the entire program at once.
The other option is to force "pasteclip" to load by selecting it from the pulldown (or context menu if available, I don't recall if that's part of 2002).
Once you initiate the command it will stay loaded for the session.
If you want to go further, I would recommend the Autocad discussion groups.
Maybe I can help. We regularly export to AutoCAD 2002 without issue to send to engineers. Am I understanding you are opening the exported AutoCAD file by importing it back into Vectorworks or do you have a copy of AutoCAD on hand to do your check?
Jeff
Never mind, I see you have a version of AutoCAD to do the check. Here is what we do; export as dwg 2000 / 2000i / 2002, convert classes to layers, invisible classes are exported as invisible layers, map line weights to colors. Everything else is default.
No problems copying and pasting from one AutoCAD file to another. We do this on every job for the engineers etc. In fact we open the drawing in AutoCAD and save it to a new file IN AutoCAD which dramatically reduces the file size.
Hope this helps
Jeff
Brudgers: pasteclip works in all other drawings, yet is temperamental in anything exported from VW. Something goes pear-shaped during export/import.
Mr Krentz: Those are the exact settings i'm using. Oddly enough, certain things can be copied, but 99% not. I'm assuming it's something to do with the class mapping during translation but i've no idea.
Like I said, it looks like a demand loading issue...the syptom is classic.
What triggers it with a nine year old version of AutoCAD is just guess work...Like I said, try invoking it from the command line or from the pulldown if the context doesnt work.
It's definately not a vectorworks issue.
BTW, I can copy and paste your drawing just fine in ADT2004.
Try setting "demandload" to "0"
Edited by brudgers
I don't want to sound like a total idiot but.....
Instead of exporting from VW to AutoCad does it make a difference if you are in AutoCad and "IMPORT" it?
Brudgers: Tried both, no luck. Indeed we tried it in acad arch 09 and it's fine. I'll test the demandload thing, thanks
Brendan: If we insert the exported drawing as a block and explode it, no problems. Or did you mean import the VW file itself? (which I wasn't aware you could do)
Brudgers: Brendan: If we insert the exported drawing as a block and explode it, no problems. Or did you mean import the VW file itself? (which I wasn't aware you could do)
If the "Block" works you might be better off...
What I was doing was "EXPORTING" from VW as a dxf/dwg and then OPENING it in AutoCAd.
Biggest problem was that VW seems to have a lot more geometry to it's drawings than AC.
