Hugo Posted April 24, 2009 Share Posted April 24, 2009 (edited) I am using VW 2009 in Spanish and I am having serious trouble with snapping. In VW 2008 and previous, each time I was drawing a line, if I moved the cursor to a line or an arc. it will always show a cue like "obect/perpendicular" or "point" or whatever, that allowed me to finish the line exactly in another one, or in the border of a circle or an arc. In 2009, I have the same snap options I have used in previous versions, but I can't get snaps to correctly help me. So my drawings are very inaccurate now, if I zoom closer I can clearly see lines do not end exactly where I wanted to, when I drag a line to snap it exactly over another one it does NOT snap correctly, almost all the time it ends very close, but not exactly over the other one. What is going on? I have tried turning on all snap cues, and also tried the different preferences with no success yet. The general sensation it gives to me is that 2009 is not precise. Anyway I can't believe this, something must be not configured. What can it be? I have searched the site for updates, but there are no service packs available for Spanish. In another post I did some days ago I was told spanish SP3 will come today. Will these bring back my snaps? Thank you for your input. Edited April 24, 2009 by Hugo Quote Link to comment
Andrew Davies Posted April 24, 2009 Share Posted April 24, 2009 VW 2009 snapping is better than 2008 so I am sure there is a preference or something you are missing. Have you double clicked the Object Snapping tool in the constraints palette and checked those options out ? Hope this helps. Buena Suerte Andrew Quote Link to comment
RubenH Posted April 24, 2009 Share Posted April 24, 2009 I think the problem could be the settings on the preferences: Interactive tab, cursor settings. Check for the size of the boxes. This is the way that better performs for me (remember it's a personal): Quote Link to comment
Hugo Posted April 24, 2009 Author Share Posted April 24, 2009 Andrew: You got it! Excellent! Double clicking over the object snapping tool was the clue; the last box was unchecked. Now precision is back... Thanks a lot! Quote Link to comment
