CAD_Boy Posted April 16, 2009 Share Posted April 16, 2009 Hello All, I am currently working on two separate plots and in the view ports two different Symbols creating in the same manner are actin very odd. They are covering up another layer and only that layer. I have tried resorting the layer order but to no success. The even weirder thing though is in the actual view they fall behind all the correct layers. Quote Link to comment
CAD_Boy Posted April 16, 2009 Author Share Posted April 16, 2009 The problem I believe it is after playing around with it is that it doesn't update the viewports with the new layer order once I change it. Anyone know how to force the viewports to update with the new layer order, I tried pressing update all layers too. Quote Link to comment
Diamond Posted April 17, 2009 Share Posted April 17, 2009 I have had a similar problem in VW2008. From memory to get around it I turned off one of the layers (in layers button on the info palette). Then I turned it back on again. Also I think I may have used the eyedropper tool to copy the viewport settings then create a new viewport. Sometimes this worked also. Cheers. Quote Link to comment
CAD_Boy Posted April 20, 2009 Author Share Posted April 20, 2009 I tried what you mentioned but that didn't help me out thanks for the idea. Quote Link to comment
David Ormsby Posted April 20, 2009 Share Posted April 20, 2009 With the Viewport selected, click the Layers button in the OIP. Viewports can override the stacking order - try clicking the Revert Stackingg Order button. Quote Link to comment
