How Posted April 14, 2009 Share Posted April 14, 2009 I try to export even the smallest file to DXF / DWG and get an error message 'Insufficient Memory: At least 62245K of additional memory required is required to initialize export' I have 4 gig of memory and i never had this on my old latop. I have changed the virtual memory up to something crazy like 100,000 Mb but still no joy. Could this be a vista problem? Thanks Quote Link to comment
0 Pat Stanford Posted April 18, 2009 Share Posted April 18, 2009 This is a know probelm with VW12 and more thatn 2GB of memory. It was fixed in VW2008 SP 2, so you could upgrade and not have the problem. Two things to try. 1. Remove memory so you only have 2GB available. 2. Try setting the compatability mode to XP Pro SP2. Good luck. Quote Link to comment
0 How Posted April 20, 2009 Author Share Posted April 20, 2009 Thanks Pat, how do i change the compatability to XP Pro? Matt Quote Link to comment
0 Pat Stanford Posted April 20, 2009 Share Posted April 20, 2009 See this post http://techboard.vectorworks.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=99925&Searchpage=1&Main=21442&Words=%2Bcompatibility+%2Bmode&Search=true#Post99925 Quote Link to comment
0 brudgers Posted April 25, 2009 Share Posted April 25, 2009 Thanks Pat, how do i change the compatability to XP Pro? Matt Right click on the icon you use to launch Vectorworks. Select "properties." Go to the compatibility Tab. Quote Link to comment
How
Thanks
4 answers to this question
