Large polygons in VW9 - worse than VW 8!
I have this polygon, well, in fact a polyline, coming from somewhere else, with 32571 vertices. With VW 8.5.2, its behaviour is erratic. When converted to a polygon, a third wont be able to be filled. When I simplify it by deleting every second vertex, it becomes manageable.
However, with VW 9 nothing helps & nothing works. If I try to convert to a polygon, VW just dies. I guess this is progress - maybe junior users like myself don't just understand how things are.
Have you submitted it to bugsubmit@nemetschek.net? I don't see anything like this in the buglist. We can't fix it if we don't know it's broken. (If you have reported it, and it hasn't been properly recorded by us, my apologies.)
Andrew Bell
andrewb@nemetschek.net
I am not an official spokesperson for NNA
No, I haven't. With this web page set-up, that is an extra step entirely - can't just cc a message to bugsubmit.
Also, I am not sure what happens to emails sent to you guys: a couple of weeks ago I received a reply from tech support saying that they only handle questions which quote the serial number. Fair enough, no problem - except that the question was posted 18 months ago.
quote:
Thanks, John, but I solved the problem with my own simplification routine which does not crash. It is a quick & dirty one, just deletes every second polygon. The one that used minimum distance ceased to work with VW 8 and I haven't had the time to rewrite the part in question.
Of course, the problem & the poly were not really mine but rather those of a client. It is somewhat awkward (to say the least) that a design practice has to have a specialist consultant on stand-by for this kind of eventualities.
It's that horrifying very quick and dirty algorithm which inspired my minimum distance script. (It probably doesn't crash or do anything bad, but i was too lazy to test it carefully and thought it best to warn as a ward against evil.)
