Pat Stanford
Set Window Marker Default Offset
This script will set the default marker distance from the wall or change the distance on selected walls. If the windows are in walls, the windows must be selected individually, but can all be changed at once.
This should be able to be converted to a Plug-in Menu item rather easily.
(************* Copy Between Here *************}
Procedure SetWindowMarkerOffset;
{If nothing in the drawing is selected, this sets the default offset distance perpendicular}
{to the wall to the value entered in the dialog box. If objects are selected, it sets the }
{marker offset for any windows selected to the value entered in the dialog box.}
{? 2009, Coviana, Inc - Pat Stanford pat@coviana.com}
{Licensed unde the GNU Lesser General Public License}
var H1,H2:Handle;
N1:Integer;
S1:String;
R1:Real;
Procedure DoIt(H3:Handle);
Begin
N1:=NumRecords(H3);
H2:=GetRecord(H3,N1);
S1:=GetName(H2);
SetRField(H3,S1,'ControlPoint03Y',Num2StrF(R1));
ResetObject(H3);
end;
Begin
If FSActLayer=nil then
Begin
Message(date(2,2),' Nothing Selected');
R1:=DistDialog('Enter Window Marker Offset','12"');
H1:= getobject('Window');
N1:=NumRecords(H1);
H2:=GetRecord(H1,N1);
S1:=GetName(H2);
SetRField(H1,S1,'ControlPoint03Y',Num2StrF(R1));
end
else
Begin
Message(Date(2,2),' Almost DoIt');
R1:=DistDialog('Enter Window Marker Offset for Selected Windows','12"');
ForEachObject(DoIt,(((PON='Window') & (V) & (SEL=TRUE))));
End;
End;
Run(SetWindowMarkerOffset);
(************* And Here *************}
and paste into a blank vectorscript editor window from the resource browser.
