genie
WINDOW TOOL
Is there a way to draw corner window with the window tool?
Vectorworks 2009
I was about to post a question with the same name so I might as well tag it on here if you don't mind.
Is there a setting that will place a window label a certain distance from the window? It seems to only be controlled by the bubble size. Our standard size for the bubble works fine at 1/4" scale but it overlaps the window at smaller scales. At 1/8" scale it just barely overlapping the window sill. This is the most common scale we use for floor plans and we basically have to manually reposition each tag or change the size of the bubble and text from what they have always used.
It seems there should be some setting for ID label offset or something.
