GWS Posted April 3, 2009 Share Posted April 3, 2009 When using a working plane and I select front view I get a certain view, fine. Then if I select front view again the view changes to another view. This seems to be a cycle of 3 views, in other words if I select front view 3 times I arrive back at the first view. Why does this happen? I have been using working planes for a while and never really understood this point. Quote Link to comment
islandmon Posted April 3, 2009 Share Posted April 3, 2009 The power of WorkingPlanes is in their innate ability to show different views based on the Objects orientation within the various coordinate planes. Obviously, the primary coordinate space is the XYZ planes, then there's the IJK planes, and finally the User selectable WorkingPlane which is a combination of XYZIJK within the ((+6)+(-6))=12D IsotropicVectorMatrix spacial coordinate system. http://www.fractalnet.org/gallery2/v/IVM/ Quote Link to comment
Guest Frank Brault Posted April 3, 2009 Share Posted April 3, 2009 Hi Guy, I see the behavior that you describe.I'll look into it and report it when I can. Quote Link to comment
GWS Posted April 3, 2009 Author Share Posted April 3, 2009 Thanks Frank. Islandmon - That sounds fascinating. Not sure how it helps or even if I understand it, but thank you anyway. Quote Link to comment
