VinceHollywood Posted April 1, 2009 Share Posted April 1, 2009 I am trying to to make a set up in a ballroom for a presentation and for a banquet. Everything including the set will be the same, the only thing that is going to change is that the presenter seating will be switched out for banquet rounds. Can someone tell me the best way to have the two layers, one with seating and one with tables? I made the presenter design layer and then copied the set and building into a new "banquet" design layer. When I did this and went back to the presenter design layer everything was grayed out. Sound I just use classes to make my life eaiser? Cheers, Vincent Quote Link to comment
cad@sggsa Posted April 1, 2009 Share Posted April 1, 2009 You siad it yourself Vincent, just switch classes on and off, will keep your drawing size smaller too. Quote Link to comment
