Drawing white lines on a grass tennis court
Hello -
I need to draw a 3d tennis court.
I have everything drawn in 2d already but am stumped as to the best way to draw it in 3d.
I could make the grass a floor and add a texture, but what would be the best way of drawing on the lines ? They need to be accurate so don't want to add them as a texture. How about a 3d poly or a Nurbs surface (which I don't understand !)
Any suggestions !?
Many thanks,
Andrew
The Dupont Zodiac textures are from Zodiac corian products.
CC_CloudWhite works well because it has the granular texture available for the necessary transparency effect.
The image is composed of 3 layers:
1) Thin White line overlay with transparent mask
2) Block with a Grass texture
3) Block of sod with a Zodia texture of some sort.
Both the Zodiac & Cambria Series provide sophisticated textures with infinite possibilities.
Hello chaps -
I hope you don't think I am just getting you to do my work for me - but this is my next question - the net.
I have made a texture called net, used grid colour and got the net the right size.
But I can't get the transparency to work. I thought grid transparency would have worked, but it gave me a solid. Have got fairly good results by just reducing the transparency of the whole texture, but it is not great.
Any ideas ?
Thanks all
Andrew
To get a net to look like a net takes a wee bit of effort.
Rendering an aviary with a specific sized stainless wire mess brought that lesson home a few years back.
The key is to not only get the transparency 'knock-out' color right but also to allow the wires to be modeled with a soft gradient to diffuse the lighting without setting up a series of moire patterns across the scene.
Grid transparency has nothing at all to do with it.
You must first model the wire mesh with the exact gauge & spacing .. then render it to get the correct look to the gradient. Finally fill in the holes with a knock out color compatible with the over all scene. Then create the final texture with a transparency mask using the knock-out color ... apply contrast & softness as required.. depending on the focal length of the image. Higher values of contrast for close ups with less softness, etc. You may need to compose a couple versions depending on the scene.
Hi Andrew, here is a screenshot one of many playing fields/courts I have created. The VW's object is a 2d/3d Symbol. I used a texture for chain link fencing for the net (I fiddled with the size of the texture mapping a little). Basically, the court itself is a single extrude, and the lines are a second, slightly thicker, extrude. Let me know if you have further questions.
