Andrew Davies
Drawing white lines on a grass tennis court
Hello -
I need to draw a 3d tennis court.
I have everything drawn in 2d already but am stumped as to the best way to draw it in 3d.
I could make the grass a floor and add a texture, but what would be the best way of drawing on the lines ? They need to be accurate so don't want to add them as a texture. How about a 3d poly or a Nurbs surface (which I don't understand !)
Any suggestions !?
Many thanks,
Andrew
I would draw a polygon in Top/Plan view, extrude it, switch to front view and make it a hair above the grass.
Per Ray's post ... a separate 3D object overlayed with just the lines having a variegated masked-semi transparent texture would do the trick.
Here's an example using a Dupont Zodiac texture and converting the grains to transparent mask for the painted lines:
Wow ! Fantastic - thanks so much.
Not sure what a Dupont Zodiac is, but I added your CC_Cloud image as a texture to my 3d Polys. Works well.
Many thanks,
Andrew
Islandmon
Just so I understand it correctly, CloudWhite is the texture you used for the lines and made a separate 3D object to the grass, inotherwords overlaying it??
The Dupont Zodiac textures are from Zodiac corian products.
CC_CloudWhite works well because it has the granular texture available for the necessary transparency effect.
The image is composed of 3 layers:
1) Thin White line overlay with transparent mask
2) Block with a Grass texture
3) Block of sod with a Zodia texture of some sort.
Both the Zodiac & Cambria Series provide sophisticated textures with infinite possibilities.
Thanks a million Islandmon
Added to favorites....
These will help alot with the texturing for the walls of the venues I draw up.
Hello chaps -
I hope you don't think I am just getting you to do my work for me - but this is my next question - the net.
I have made a texture called net, used grid colour and got the net the right size.
But I can't get the transparency to work. I thought grid transparency would have worked, but it gave me a solid. Have got fairly good results by just reducing the transparency of the whole texture, but it is not great.
Any ideas ?
Thanks all
Andrew
To get a net to look like a net takes a wee bit of effort.
Rendering an aviary with a specific sized stainless wire mess brought that lesson home a few years back.
The key is to not only get the transparency 'knock-out' color right but also to allow the wires to be modeled with a soft gradient to diffuse the lighting without setting up a series of moire patterns across the scene.
Grid transparency has nothing at all to do with it.
You must first model the wire mesh with the exact gauge & spacing .. then render it to get the correct look to the gradient. Finally fill in the holes with a knock out color compatible with the over all scene. Then create the final texture with a transparency mask using the knock-out color ... apply contrast & softness as required.. depending on the focal length of the image. Higher values of contrast for close ups with less softness, etc. You may need to compose a couple versions depending on the scene.
Hi Andrew, here is a screenshot one of many playing fields/courts I have created. The VW's object is a 2d/3d Symbol. I used a texture for chain link fencing for the net (I fiddled with the size of the texture mapping a little). Basically, the court itself is a single extrude, and the lines are a second, slightly thicker, extrude. Let me know if you have further questions.
Thanks Ray! I call it "real grass" and it's from a photo of a lawn. It is a little less cheesy than the grass (or turf) textures that ship with RW's. It has those realistic brownish splotches (like my lawn!).
Yah, it's the brown spots that make it look real. I'd love to have it.
Especially for those of us in drought stricken California. I surmise most lawns will be looking more than a bit patchy brown this summer.
Really helpful everyone !
Many thanks.
Andrew
PS - Have only been using VW seriously these last few weeks and am amazed by it. Wish i'd got into it sooner. My clients love the stuff I am sending them !
