Rosetter Posted March 23, 2009 Share Posted March 23, 2009 Hi, I made it through all the tutorials I could and seemed to have a grasp on rendering but I guess not. I am working on a design and would like to provide a simple 3-D presentation and am having troubled applying textures to structure walls and landscape walls. It shows the texture is associated with my walls but when I render it the walls disappear all together. If I hover over them the outline appears. I have tried changing the attributes with no luck. Any suggestions? Quote Link to comment
Ray Libby Posted March 23, 2009 Share Posted March 23, 2009 Make sure they have a solid fill in the attributes palette. Quote Link to comment
Rosetter Posted March 24, 2009 Author Share Posted March 24, 2009 Thanks for the reply Ray, but that does not seem to be the problem. Another issue I am having which may be related is everytime I render in any mode, I get an error saying insufficient memory. I have a make with 4GB memory and the file is roughly 50mb so I wonder if it is a glitch with the program? Definately could be operator error as well! Please let me know what you think. Thanks again Quote Link to comment
landscape archiberry Posted March 31, 2009 Share Posted March 31, 2009 Some objects can only be rendered through their class settings, I've found. Create a class for your wall, like 'Brick wall class' and give it a render in the edit class box. Choose use at creation. Then make sure the render tab in the OIP is set to class render. Good luck! Quote Link to comment
