importing image from illustrator
What is the best way to import a logo from illustrator 8 into VW 8.5.2 on a mac g4. I tried EPS and I get a grain to my image. I tried pict and the geometry is a little screwed up. Tiff gives me memory problems. Which one should I push on? Or maybe there is a fourth way. Any help is much appreciated. Thanks.
I just tried pismox's trick and it works just fine from AI8 to VW8.5.2, though you paste a bitmap.
If I do the same thing on my AI9.0.2/VW9 machine, the paste results in polygons and bitmaps. For example, a filled path in AI pastes a vector path for the path, and a bitmap for the fill in VW, stacked on top of each other. The polygon can be reshaped in VW.
