dtheory Posted March 19, 2009 Share Posted March 19, 2009 (edited) Hi Guys, Has anyone had this issue before? It seems that when using the callout tool as an annotation within a viewport, If there is "sketch hidden line" applied to the viewport, the callout tool arrowhead does some funny things duplicating, pointing the wrong way... .. see the attached files.. Mac Pro 2008 2009 SP2 99197 OS X 10.5.6 Edited March 19, 2009 by dtheory Quote Link to comment
monkey Posted March 19, 2009 Share Posted March 19, 2009 there is an option to have a curved callout, you sure this is not switched on? Quote Link to comment
dtheory Posted March 19, 2009 Author Share Posted March 19, 2009 Hi.. yes the leader line is set to "arc" what I am referring to is in picture2.jpg; the arrowhead has duplicated and pointed in the opposite direction Quote Link to comment
dtheory Posted March 19, 2009 Author Share Posted March 19, 2009 solution is to make sure sketch is turned off in the OIP for each individual callout placed within the annotations space of the viewport, then the viewport can be rendered as desired and the callouts remain correct Quote Link to comment
Pat Stanford Posted March 19, 2009 Share Posted March 19, 2009 You should not have to unselect callout for sketching. Please submit this as a bug. Quote Link to comment
