Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
Bostonluke
missing plant outlines
VW 2008
When I activate a class for my plants, the outlines disappear for plants already placed on the plan; all I'm left w/ is the center tick. Does anyone know why this is happening and how I can correct it? Thanks.
P
Make sure your class settings are not "Active Only"
Assuming that this is not the case, I am thinking that your placed plant object has objects internal to it that are classed. (this was probably the active class before you made the change)
Try setting the classes to visible one at a time until they show up. That will tell you what the internal class it.
Thanks for the suggestion. However, I'm at a loss. I have two classes that are affected: Plant Material-Tree and Plant Material-Perennial. When going thru visibility, one class at a time, only the ticks came up when got to Perennial. I highlighted everything and clicked on the same class in Obj. Info. the program was churning and the outlines came up. However, when I did the same thing for trees, only the ticks remained. I went back to Perennial visibility and only the ticks were there. Can you suggest someothing else for me to try? Thanks.
P
P
Plant symbols are made up from components from many different classes. You need to ensure that all classes relating to a plant are visible, not just those listed in the object info palette.
Look under the plants/components class. All the sub classes should be visible - unless of course you want to turn off a particular component.
I have just discovered that the oultlines for the "missing perennials" is connected to the None layer. I've never noticed this before. Is there a way to move this infor from None to Pwerennial, or at least one of the Plants-Component layers? Thanks.
P
If they disappeared because you turned off visibility of the none class, I would turn it back on. Its difficult to justify why, but to be honest, the none class should always be visible. Its a default class, for things that don't fit logically within another class - ie all viewports that you may create should be in the none class.
http://techboard.nemetschek.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=116562
If you do want to change the class for the plant components, you need to edit the underlying plant symbol, but this won't change the plants already placed, unless you edit each one separately.
My advice is not to fight certain in grained ways of doing things in Vectorworks, such as always keeping the none class visible. Odd things can happen if you go against the grain.
