Robert Darden Posted March 11, 2009 Share Posted March 11, 2009 I am designing two different building that will eventually become part of a complex of six buildings. Is there an way of taking the two designs and copying them to the larger site plan without having to re-draw all the buildings on the site plan? Quote Link to comment
J Lucas Posted March 11, 2009 Share Posted March 11, 2009 I assume the site plan is in a separate file. Is it a Vectorworks file? If so, you could reference a viewport of each building into the site plan. If you get the settings right, the referenced veiwports will automatically update in the site plan file. Quote Link to comment
Robert Darden Posted March 11, 2009 Author Share Posted March 11, 2009 J Lucas, Thanks for the information. If I do viewports, will I also be able to project elevations of the imported plans? Quote Link to comment
Guest Wes Gardner Posted March 11, 2009 Share Posted March 11, 2009 Hi Robert, As J Lucas suggests, you should use the power of referencing to get the job done (it will also keep the file size to a minimum). Yes, you will be able to "cut" all of your elevations and sections from the "master" file (the one with all the buildings and site incorporated into it) You might want to do a small test file first so you "get the hang" of referencing and manipulating the viewports. Let us know how it goes. Wes Quote Link to comment
