mr. iagea
3D Wall Reshape Tool
It would be nice to have the 3D Wall Reshape tool accessible from the toolbox, in the same way that the 3D Reshape tool is available now. Perhaps the 3D wall Reshape can be set as a sub-tool of the 3D Reshape tool.
1 answer to this question
Charlie there is not a unique 3D Wall Reshape tool. It is the 3D Reshape tool. It looks different on the Mode Bar because Walls have different edit options to other 3D object - vertices that can be moved and you can add or subtract vertices.
To see how the Mode Bar options change depending on how the 3D object can be edited try drawing a range of 3D objects using the 3D Modeling toolset. Make sure you include a 3D polygon and a Nurbs curve. Select the objects one by one and then activate the 3D Reshape tool. Notice how the Edit options change for each of the different 3D objects.
