michaelk Posted March 5, 2009 Share Posted March 5, 2009 I'd like to be able to insert hybrid symbols on a working plane that is not parallel to the ground plane. Currently only 3D symbols will insert. michaelk Quote Link to comment
0 mike m oz Posted March 6, 2009 Share Posted March 6, 2009 The only 2D representation a hybrid symbol can have is the Plan view one. Therefore Plan is the only view it can be seen in and the objects are restricted to being installed parallel to the Ground Plane. Quote Link to comment
0 michaelk Posted March 6, 2009 Author Share Posted March 6, 2009 That's my request. I want the 3d to be restricted to the working plane, and let the 2d act normally in the ground plane. Quote Link to comment
0 AndiACD Posted March 6, 2009 Share Posted March 6, 2009 ???? Michael, You'll have to explain this one. As i understand it, that's how it already works. Quote Link to comment
0 michaelk Posted March 6, 2009 Author Share Posted March 6, 2009 Andrew I've tried it several times, and I can't make it work. Maybe you can. Make a 3D ramp. Create a working plane on the incline of the ramp. Switch to the working plane view. Take a hybrid symbol (say a baby grand piano) and try to place it on the ramp. It won't go. At least it won't land on the ramp. But if you remove the 2D part of the symbol, it works perfectly. The piano will sit with all 3 legs on the ramp in any orientation. If you can make a hybrid symbol sit on a ramp, I'd love to know how you do it. michaelk Quote Link to comment
0 AndiACD Posted March 6, 2009 Share Posted March 6, 2009 Yeah, i know what you mean. This is unfortunately one of the bugs i could never understand with Hybrids, you can ONLY rotate them if you remove the 2D element. Some find it useful, you and i obviously don't. i had made many querries about this, suggesting it should be changed and made an option to be able to rotate them in any view but the consensus is that it stays as it is. The only way around this that i can see, is to plant two Grand Pianos and make one, the hybrid only visible in the Plan view and the other(less 2D parts) only visible in all other views. Hardly a suitable solution, but probably the only one that can help, unless of coarse there is someone else out there with a more practical one. Hope this helps . . . Quote Link to comment
0 AndiACD Posted March 6, 2009 Share Posted March 6, 2009 (edited) i realise that using this method doesn't allow for foreshortening of the piano in plan, but, i'm afraid you're stuck with that result. i suppose you could always use the tape tool, measure the length the piano covers once inclined and then use the scale tool to shorten the hybrid to the required new plan length. Maybe? ? ? ? ? BTW just remembered, it was Mike and Pat that pointed out the "Hard Line Facts" about hybrids . . . . . . Edited March 6, 2009 by AndiACD Quote Link to comment
0 panta rhei Posted March 6, 2009 Share Posted March 6, 2009 I can't but feel sorry for the poor pianist... There's no immediate & practical solution to this, but a clever programmer could perhaps write a universal plug-in object that could take any hybrid symbol, break it into 2D and 3D components and then allow the 3D-part to be tilted. Probably not by working plane, though. Quote Link to comment
0 AndiACD Posted March 6, 2009 Share Posted March 6, 2009 But the 2D element would still need foreshortening though, panta. Quote Link to comment
0 panta rhei Posted March 6, 2009 Share Posted March 6, 2009 At least if the angle is more than x?, yes. Should be doable. Quote Link to comment
0 AndiACD Posted March 6, 2009 Share Posted March 6, 2009 Doable without a doubt. Depends on how much strain it puts on VW as a whole. Quote Link to comment
0 panta rhei Posted March 6, 2009 Share Posted March 6, 2009 Well, that depends. If we put a grand piano (even a baby grand) on a ramp, one or more legs will become visible in plan view. In some circumstances even the pedals & castors need to be shown. So in effect we need to generate a hidden line top view and then process that to look like a plan with fills. Quote Link to comment
0 michaelk Posted March 6, 2009 Author Share Posted March 6, 2009 Believe it or not, I have spent a lot of time drawing baby grand pianos on raked platforms.... And you're right, the piano players don't like it. And the piano movers really don't like it. Petri, I like your idea of generating a hidden line top view and processing that view as the piano tilts. Until then I'd be content with just keeping the 2D in the bounding box and letting the 3D behave like a 3D symbol. michaelk Quote Link to comment
0 AndiACD Posted March 6, 2009 Share Posted March 6, 2009 Well . . . . . . Glad we got that one sorted!! Quote Link to comment
0 panta rhei Posted March 6, 2009 Share Posted March 6, 2009 Ah well, I guess pianists who accept one insult (the baby grand) are inclined, so to speak, to accept another one just the same. I dare not to think what they are supposed to play... (Sorry, I have a musician in the family.) Anyway, with a fixed 2D part such a PIO shouldn't be too hard to write. Hopefully you find someone ? unless you decide to write it yourself. Quote Link to comment
0 michaelk Posted March 15, 2009 Author Share Posted March 15, 2009 Actually, the ability partially exists in Spotlight lighting instrument objects. I don't think you can insert them on an inclined working plane, but you can insert them and then in the OIP rotate the object around the X or Y axis - without affecting the 2D part of the symbol. I suppose it's possible to turn a piano into a lighting instrument..... michaelk Quote Link to comment
michaelk
michaelk
15 answers to this question
