wma Posted March 4, 2009 Share Posted March 4, 2009 (edited) This is a problem that crops up now and again ... I import something like a manufacturer's detail section through a window from profile. The import process sometimes seems to convert complicated polylines and curves into thousands of little linked lines. This obviously makes the imported stuff terribly unwieldy and bogs down any drawing I include it in. Is there way of simplifying these drawings automatically... losing a bit of accuracy or detail (which is generally much more than I need anyway) in exchange for less lines? Or is there something I should be doing at the import stage to stop this happening? edited to add: In the instance I am dealing with at the moment I have imported a drawing which seems to have been partly created in 3d so I am getting loads of "3d polygons" (about 3900 of them for a drawing of a single window frame) which I am trying to convert into 2d polygons (resulting in thousands of those instead - 23000 objects to be precise!) Edited March 4, 2009 by wma Quote Link to comment
monkey Posted March 4, 2009 Share Posted March 4, 2009 you have the option when importing to import only 2D or only 3D or both, you could try importing only 2D Quote Link to comment
wma Posted March 4, 2009 Author Share Posted March 4, 2009 you have the option when importing to import only 2D or only 3D or both, you could try importing only 2D If I do that, half of the drawing just isn't imported at all. Quote Link to comment
