Switching Between Open Drawings Bug
Unless I forgot how to do this from VW 2008 to VW 2009 then something has to be wrong here. If I'm in full screen mode and have multiple open drawings and want to switch between them I go to the menu Window->Drawing1.vwx when I'm currently viewing Drawing2.vwx and vice versa if I want to switch what I'm viewing. Well, when I do this, absolutely nothing happens so I'm left minimizing one and enlarging the other. Is this happening to anyone else? Is there a command shortcut to scroll through open documents?
I have restarted VW and the computer many times. This has been a problem since I installed 2009 a while back, but I've lived with it.
Ozzie- thanks the Ctrl Tab works perfectly, which leads me to be even more confused with the menu commands not working at all.
