JGraber Posted March 3, 2009 Share Posted March 3, 2009 Unless I forgot how to do this from VW 2008 to VW 2009 then something has to be wrong here. If I'm in full screen mode and have multiple open drawings and want to switch between them I go to the menu Window->Drawing1.vwx when I'm currently viewing Drawing2.vwx and vice versa if I want to switch what I'm viewing. Well, when I do this, absolutely nothing happens so I'm left minimizing one and enlarging the other. Is this happening to anyone else? Is there a command shortcut to scroll through open documents? Quote Link to comment
Ray Libby Posted March 3, 2009 Share Posted March 3, 2009 I've never had this happen with any version, something is definitely wrong. Some things to try: Update to SP2 Switch to another workspace. Create a new Vista user account and try that. Reinstall VW. Quote Link to comment
JGraber Posted March 3, 2009 Author Share Posted March 3, 2009 I do have SP2...need to update profile Switching to another workspace does not work. I'll keep trying Quote Link to comment
Ozzie Posted March 3, 2009 Share Posted March 3, 2009 Try Ctrl Tab to switch between open drawings Quote Link to comment
Pat Stanford Posted March 3, 2009 Share Posted March 3, 2009 Have you restarted VW and the computer? Quote Link to comment
JGraber Posted March 4, 2009 Author Share Posted March 4, 2009 I have restarted VW and the computer many times. This has been a problem since I installed 2009 a while back, but I've lived with it. Ozzie- thanks the Ctrl Tab works perfectly, which leads me to be even more confused with the menu commands not working at all. Quote Link to comment
Jeffrey W Ouellette Posted March 4, 2009 Share Posted March 4, 2009 Josh, This shouldn't be happening and I haven't seen the same behavior. Please contact Tech Support. Quote Link to comment
J Lucas Posted March 4, 2009 Share Posted March 4, 2009 I am having this same problem. It was not happening when I first installed 2009 but now it is. Quote Link to comment
JGraber Posted March 4, 2009 Author Share Posted March 4, 2009 Jeffrey I contacted Tech support so we will see what they say. Quote Link to comment
J Lucas Posted March 7, 2009 Share Posted March 7, 2009 Any results from tech on this issue? Quote Link to comment
