AMCCLENDON Posted February 25, 2009 Share Posted February 25, 2009 I was wondering if anyone had any suggestions for me. I need to do a final shaded polygon render with perspective in my viewport. I've found that it looks fine in orthagonal, but when I change my projection to perspective a small viewport box shows up with nothing in it. I was able to view the viewport in the "cavalier" perspectives, but these are not what I'm looking for. Any suggestions would be greatly appreciated. Thanks! Quote Link to comment
Chad McNeely Posted February 25, 2009 Share Posted February 25, 2009 This always seems to work best for me if starting from a design layer. Use the camera tool or the "Set 3d View" command to get the view you want, draw a rectangle (or whatever) that you will use as the cropping geometry. With the crop selected, select Create Viewport, it'll ask if you want to use the cropping object, say 'yes', then select the sheet layer you want. Once on the sheet layer, you can modify the view, the classes and layers visibilties, etc. You can also use the walkthrough and flyover tools inside the crop edit mode, which isn't necessarily intuitive. One caveat is that you can't adjust the crop while the scene is rendered, as this will kill the render cache. Quote Link to comment
AMCCLENDON Posted February 25, 2009 Author Share Posted February 25, 2009 Thank you...thank you....thank you!!! I was not aware that I could generate a viewport from the design layers! I have been creating viewports directly from the sheet layer. This will be very helpful to me! Quote Link to comment
mar schrammeyer Posted February 26, 2009 Share Posted February 26, 2009 After creating a VP one can adjust the view by using fly over tool in crop mode Quote Link to comment
Gilbert Osmond Posted July 30, 2015 Share Posted July 30, 2015 Interesting, I am having the OP's (original poster) exact same issue in VW2015 SP4 (with renderworks.) I have created a viewport from 2 or 3 design layers, all at the same scale, nothing super fancy. When I go to set the Render options for the viewport, Orthogonal & Cavalier views work fine, but when I select "Perspective" I get the same tiny (~10 or 12 pixels square) box in the middle of an otherwise-blank Sheet Layer. When I change the perspective to "Orthogonal" and do Update the viewport instantly appears as it should. Any further thoughts on this? Should I attach a sample file? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 30, 2015 Vectorworks, Inc Employee Share Posted July 30, 2015 File > Document Preferences > Document Settings, under the Display tab uncheck "Cropped Perspective" Its a holdover from the older perspective views in documents or templates from a ver versions back. In new files it should be disabled by default, and you can update your templates to remove this setting if it keeps happening in your documents. Quote Link to comment
Gilbert Osmond Posted August 1, 2015 Share Posted August 1, 2015 Thank you, that fixes it. Quote Link to comment
