window and door dimension
HAUSrucker
1. You can't. The dimension line is not able to query the height of the window.
2. You can. Apply dual dimensioning (you'll need to define a dimensioning standard) and enter the height manually (& suppress the actual dimension value.) In case of chain dimension, ungroup the dimension line and apply DD to the relevant part.
3. I don't think you can. The half-centimeter notation is not, AFAIK, possible. Unless the good people at ComputerWorks have done something magical.
  • 12 years later...
