directional lighting--explain...
kgroob
I know that directional lighting uses parallel beams of light, but do these beams then exist throughout the entire design layer, or does the location of the light source make a difference? For instance, would something be lit by the directional light source that is behind the arrow of the beam?
If I put four directional light sources 20'-0" apart from one another in a plane, does that just make the brightness increase four-fold?
