wvancampen Posted February 20, 2009 Share Posted February 20, 2009 In 2D, how do you make a window appear with a different (say darker) fill for the cut parts (eg jamb, sash) and lighter fill for the rest (eg the sill below)....as per graphic convention? With a door it's straightforward--the fill attribute appears for the leaf and the jamb/trim, and everything else not. With a window everything (jamb, trim, sash, sill etc) gets that fill. As far as I can tell, differentiating parts via Window Settings/View/Special Classes only affects rendering and 3D, not 2D projections. And parenthetically I don't understand the purpose of the Sills class, which is created automatically with doors and windows. Quote Link to comment
Guest Wes Gardner Posted February 20, 2009 Share Posted February 20, 2009 The Attributes Palette for doors and windows should be set up thus: ? Fill Style-by Class, ? Fill Color-by Class, ? Pen Style-SOLID (NOT by Class), ? Pen Color-by Class ? Thickness (Line Weight)-NOT by Class ? These settings will allow the line weight set up in ?Use Part Line Styles? dialog to show correctly in sheet layers ? don?t forget to bump up ?Wall Lines? line weight for RCP (Controlled by Ceiling-Main Class). The ?Sills? class can turn off the door swing for RCP?s Quote Link to comment
wvancampen Posted February 20, 2009 Author Share Posted February 20, 2009 Ok, thanks--I now understand how to activate "Use Part Lines Styles." But how do you give a fill to jambs/trims but not to sills/stoops? Quote Link to comment
BLINK Design Posted February 22, 2009 Share Posted February 22, 2009 Ok, thanks--I now understand how to activate "Use Part Lines Styles." But how do you give a fill to jambs/trims but not to sills/stoops? I am having that same issue. How do you NOT fill the sill? WHY is there a fill and why doesn't it respond to the class setting? Quote Link to comment
