Jodyb17 Posted February 18, 2009 Share Posted February 18, 2009 Did a search, but didn't see anything... Quote Link to comment
Pat Stanford Posted February 18, 2009 Share Posted February 18, 2009 Unfortunately, it is not possible to copy a saved view between files using the standard methods. It might be possible to write a vectorscript that would write a file that contained the information necessary to reconstruct the view and then a separate script that would read in the file and make a new saved view with the same settings. While technically possible, there are questions about numerous edge cases. What do you do about Layers that don't exist in the new file? Create them, ignore them? What about Classes? What about Layers and Classes that do exist in the new file, but are not in the original file? Ignore them? Make them visible? Make them invisible? No easy answers on this one. Quote Link to comment
gmm18 Posted February 18, 2009 Share Posted February 18, 2009 Same thing applies to being able to Copy/Paste a Sheet Layer Viewport into another file. Quote Link to comment
Guest Wes Gardner Posted February 19, 2009 Share Posted February 19, 2009 You can however copy and paste CAMERAS...maybe that'll help? Quote Link to comment
cad@sggsa Posted February 19, 2009 Share Posted February 19, 2009 I have before had a saved view I wanted to use in another drawing so I saved that whole drawing as a new one and deleted what was not needed. The classes I ignored to a point as some I could reuse for the new drawing. Quote Link to comment
C. Andrew Dunning Posted February 19, 2009 Share Posted February 19, 2009 Have any of you looked at "Merge Organizations" from Software Customization Services (http://scs-inc.us/default.php?page=products&subPage=Products/Merge%20Organizations/Default) This command/tool might do what you're needing. Quote Link to comment
Jodyb17 Posted February 20, 2009 Author Share Posted February 20, 2009 Thanks for the input guys! Quote Link to comment
