al Posted May 17, 2001 Share Posted May 17, 2001 I Just built an Atholon 1 GHz PC w/ 256 meq ram, 32 meg G-Force graphic card under win98 se (all for under $700) ;-) VW 8.5.2 Is crashing where it almost never did before. Any Ideas & will V9 be more stable on higher speed proccesors. Otherwise the program jets but RenderWorks rendering is disapointing.Expected a bigger improvement. Thanks, AL. [This message has been edited by al (edited 05-17-2001).] Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted May 18, 2001 Vectorworks, Inc Employee Share Posted May 18, 2001 When it crashes, does it give you any info about where? If you get something like DDraw.DLL, for example, I think it may be possible that you have a version optimized for P3s rather than Athlons, and that could cause a problem. Otherwise, the speed of the CPU should not be an issue. ------------------ Andrew Bell andrewb@nemetschek.net I am not an official spokesperson for NNA Quote Link to comment
