powell432 0 Posted February 17, 2009 currently i am printing at 300 dpi but it seems like i am still losing some details when i plot on my hp designjet 130nr. any suggestions Quote Share this post Link to post
0 Pat Stanford 1,527 Posted February 17, 2009 Where are you printing from? If you are printing sheet layers, you need to make sure the Sheet Layer DPI (set in the orgianization palette) is also set to 300 DPI as well as the setting in Document Preferences. Quote Share this post Link to post
0 powell432 0 Posted February 17, 2009 thanks that was my problem i never changed the dpi in the document preferences Quote Share this post Link to post
0 islandmon 4 Posted February 17, 2009 Keep in mind ... also... that each printer / plotter has a maximum print resolution. Experience has proven 300dpi to be a normally satisfactory compromise between filesize, print time, and output quality. Quote Share this post Link to post
0 Stan Rostas 0 Posted February 17, 2009 150 dpi on most printers and with most eyeballs is not any difference than 300 dpi. Random test were done at a local university to test this theory and 80% of the test subjects could not tell the difference. Quote Share this post Link to post
0 mr. iagea 1 Posted March 23, 2009 High-resolution 4-color process resolution is usually 300 dpi because the screen lpi is 150 (multiply x2 to get resolution). If you are printing high-res photo-quality process, then 300dpi is what you want. Usually 260dpi is sufficient for color printing on most "end-user" printers, even with those special glossy "photo papers". Anything higher than that and you're wasting ink and time. For black and white plots, 150 dpi is plenty. You will not see any noticeable difference with resolutions higher than that. If you are losing detail in your output, I would suggest checking your printer settings (on the actual printer), to assure that you are printing at the Highest Quality setting, rather than "Normal" or "Draft", if such settings are part of your printers firmware or software drivers. Quote Share this post Link to post
