cameleyes Posted February 17, 2009 Share Posted February 17, 2009 I'm guessing (but just wanted to check from experienced users) there is no way to turn off a gradient fill in a viewport other than assigning it to a class? Thanks Matt Quote Link to comment
gmm18 Posted February 17, 2009 Share Posted February 17, 2009 You're basically correct. Knowing of course that you can also use Design Layers to control visibility. I thought of suggesting the use of VP Class Overrides, (Where you assign attributes to a class using the class properties and "Use at Creation" checked. Then in the OIP change the class attributes in that VP.) BUT, class overrides does not seem to work with Gradients. Quote Link to comment
cameleyes Posted February 17, 2009 Author Share Posted February 17, 2009 Frustrating! Yeah the only way I can think is a Class in the Design Layer either change the fill or change to gray only and then create Viewport. If anyone has any other suggestions - most welcome! Quote Link to comment
