bolldo Posted March 22, 2004 Share Posted March 22, 2004 Howdy... I need to export my 3d solid as a SAT file (going into a cadcam machine). What's the best way to do this from Vectorworks 10? Thanks B-- Quote Link to comment
Bart Rammeloo Posted March 23, 2004 Share Posted March 23, 2004 Doesn't work that way. VW doesn't support SAT files. Exporting to DWG converts your organic 3Dmodel to tesselated geometry, so that's not a good solution. The only way left is IGES export. Of course, if your model is "flat", you might as wel use DXF. Good luck, BaRa [ 03-23-2004, 03:40 AM: Message edited by: BaRa ] Quote Link to comment
bolldo Posted March 24, 2004 Author Share Posted March 24, 2004 hi bara thanks for the info... so do you mean i should export as IGES and then somehow convert the IGES into a SAT file? how would i make that next stage, what app could i use to do that? (my model ain't flat!) Quote Link to comment
Chris Dordoni Posted March 24, 2004 Share Posted March 24, 2004 Bolldo, Rhino will read in IGES and save as SAT. You can download the evaluation version of Rhino at the following link: http://download.mcneel.com/rhino/3.0/eval/default.asp The eval version of Rhino will let you save 25 times. After that it works as a viewer only. FormZ will also do this conversion, if you know anyone that has it. Regards, Chris Quote Link to comment
tom kyler_dup1 Posted May 6, 2004 Share Posted May 6, 2004 Bolldo, Charlene is right, VW11 has *.SAT export and it does work nice, I've exported a few parts for CNC already; however, check your CAM software, many packages will import IGES and can construct nurbs (smooth) machinable surfaces from IGES files that aren't "faceted" or made from flat triangles. I haven't had good luck with IGES export from Vectorworks though. If you can afford the upgrade to VW11, the SAT export works great and will solve a lot of headaches and time (worth the upgrade price alone). But if you're just doing a few parts, the evalation of Rhino 3D mentioned above is a great choice. File translation through multiple programs is risky in my CNC experience, but SAT has always been reliable for me. [ 05-05-2004, 12:26 PM: Message edited by: tom kyler ] Quote Link to comment
