Marietta 0 Posted February 6, 2009 I have recently upgraded to VW 2009 and am having problems organizing my plant lists as I did in VW12. I divided my plant lists into Trees, Shrubs, and Perennials by changing the headers to include only those plants. These were all in one plant list. When I do this in VW 2009, the trees work fine, but under shrubs or perennials, I can only get it to calculate each instance of a plant and not summing up each plant species. So, for example, if I place Shirobana Spirea three times on the plan, the plant list would give me three lines for the Shirobana instead of one total. If I look under the headers for the trees, I see that it has a sum done for the numbers, but I get an error message if I try this for the shrubs or perennials saying that it cannot calculate past a certain line number. If I separate the plant types into separate plant lists, I am fine. Is there any way to get them into one plant list? Quote Share this post Link to post
Dave P 0 Posted February 7, 2009 This function seems to work fine for me in 2009. Two probably dumb questions: - Are you sure the header lines are showing when you try to sum and - Are you summing the field (e.g. Plant ID) rather than the quantity? Otherwise, posting a copy of the file here might help. Quote Share this post Link to post
Marietta 0 Posted February 10, 2009 Thanks - I was not dragging the icons properly to the columns. I got it to work by reinserting the sum function, but I don't know why they disappeared when converting a file from VW12 - with plant lists that sum properly in the categories, they do not when converted to VW2009 - the sum operation is not visible in the plant ID anymore. Now I just have to get comfortable with the plant symbol behavior and new database Quote Share this post Link to post
