genie Posted February 6, 2009 Share Posted February 6, 2009 Is there a way to rename "automatic classes" generated by plug-in objects and have the subsequent objects created use the renamed classes? e.g. When inserting a door, 'ceiling-main' and 'sills' are created. If I edit the names of these classes, the same ones will be generated again when I insert a second door. Thanks! VW 2009 Mac 10.5 Quote Link to comment
Stan Rostas Posted February 6, 2009 Share Posted February 6, 2009 Nope, unless you edit the Plug-in object, which is locked. Quote Link to comment
panta rhei Posted February 7, 2009 Share Posted February 7, 2009 Actually, not quite so. If the plug-in has been created with VectorScript, one can change the value lists of pop-ups & radio buttons, even when the script is locked. This may have unexpected consequences, if there is something related to these hard-coded in the PIO script. One can also assign a default class to the object, not to mention default values to be used in new files. Unfortunately, more and more of NNA's plug-ins are created with the C++ SDK API and the user cannot change anything. Quote Link to comment
islandmon Posted February 7, 2009 Share Posted February 7, 2009 Or you can go thru the hassle of exploding ( Ungrouping ) the PIO then re-assign /modify Classes & Attributes then convert it to a specific Symbol for that particular object making sure to set the correct insertion point(s). Quote Link to comment
