michaelcobb Posted May 8, 2001 Share Posted May 8, 2001 I'm running VW 8.5.2 on my G4 and have run into a problem getting a good consistant print out of my hatches. I've determined that the problem is not with the output device. Every now and then in a large field there will simply be a couple lines missing. Help! Quote Link to comment
acepernich Posted May 8, 2001 Share Posted May 8, 2001 I've run into the same problem occasionally, when editing polygons with associative hatches. Add Surface or Clip Surface will leave the hatch with seemingly random lines missing. Refreshing the image doesen't correct it. Making additional changes will result in DIFFERENT lines disappearing. I usually recreate the finished polygon with None fill, then apply the hatch. Mac G4, MacOS 9.1, VW 8.5.2 [This message has been edited by Antone Cepernich (edited 05-08-2001).] Quote Link to comment
michaelcobb Posted May 10, 2001 Author Share Posted May 10, 2001 Thanks quote: Originally posted by Antone Cepernich: I've run into the same problem occasionally, when editing polygons with associative hatches. Add Surface or Clip Surface will leave the hatch with seemingly random lines missing. Refreshing the image doesen't correct it. Making additional changes will result in DIFFERENT lines disappearing. I usually recreate the finished polygon with None fill, then apply the hatch. Mac G4, MacOS 9.1, VW 8.5.2 [This message has been edited by Antone Cepernich (edited 05-08-2001).] Quote Link to comment
