Ethan Krupp
Getting lines to print - Export PDF vs Print to PDF
Recently moved to 2009 from 9.5.2 and am having some issues with printing to pdf.
I'm working on light plots 24x36 in size, so I can't print the whole thing myself but I've got both a freeware pdf printer (PDF995) and the legit acrobat one installed so files can be emailed to print company. When I print a file with either pdf printer, the file appears fine on screen, but when I do a test print of a section of the drawing with my desktop HP printer, no horizontal lines and only parts of the small circles and hexagons print. No such issues if I use export to pdf and test print on the same printer or when I print to the HP straight from the VW file.
I had this issue back with 9.5.2, but only with the Acrobat printer.
Anyone else run into this issue?
TIA
2 answers to this question
What line weight are the lines that don't print? I have found with PDFs I need to use a minimum 0.07mm line weight for it to print.
Seems to have magically fixed itself - only thing I did was turn off GDI+ Imaging to fix the font display issue - maybe they are related some how.
Thanks!
