Bruce Kieffer Posted May 2, 2001 Share Posted May 2, 2001 VW 9 installs only the standard workspace. Where are the others that where included in previous versions. Also, where is the RenderWorks workspace that was installed in previous versions of RW? Quote Link to comment
MacDaid Posted May 2, 2001 Share Posted May 2, 2001 quote: Originally posted by Bruce Kieffer: VW 9 installs only the standard workspace. Where are the others that where included in previous versions. Also, where is the RenderWorks workspace that was installed in previous versions of RW? Bruce; If you still have VW/8.X installed, you cn go into it's application folder on your hard drive. Find the "Workspaces" folder, open & select the workspaces you want and drop them into the corresponding "Workspaces" folder in the VW/9 application folder. When you start-up VW/9 they will be in the Workspaces sub-menu under "File" menu... [This message has been edited by MacDaid (edited 05-02-2001).] Quote Link to comment
