NonPlot / Defpoints
HP Sauce
I think the operative words here are ?human" & "error?.
Whatever, if one makes a menu command of the following script (use at your own risk) and assigns CMD-P to it, instead of the normal Print -command, there is less room for error.
PROCEDURE HideNoPlotAndPrint; { ? Petri Sakkinen 2009 }
CONST
classToHide = 'NoPlot';
VAR
layerName : STRING;
layerHd : HANDLE;
ok : BOOLEAN;
PROCEDURE HideIt (h :HANDLE);
BEGIN
IF (GETTYPE(h)=122) THEN ok := SETVPCLASSVISIBILITY(h, classToHide, -1);
END;
BEGIN
HIDECLASS(classToHide);
layerHd := FLAYER;
WHILE NOT(layerHd=NIL) DO BEGIN
	IF (GETOBJECTVARIABLEINT(layerHd, 154)=2) THEN BEGIN
			layerName := GETLNAME(layerHd);
			FOREACHOBJECT(HideIt, L=layerName);
	END;
	layerHd := NEXTLAYER(layerHd);
END;
DOMENUTEXTBYNAME('Print', 0);
END;
RUN(HideNoPlotAndPrint);
  • 11 months later...
Sorry to arrive so late for this topic.
I used to use ?defpoints? a lot and would leave little notes for myself, like why this modification was made, sizes of structural members, ?note to self?, etc. In fact I pretty much used it in the way that I would use construction lines on a drawing board, but was able to leave them there for reference instead of rubbing them out!
As we are making more use of live elevations and sections, with annotations in the viewport it would be nice to have these rough notes visible in the viewport without the risk of them ever printing/plotting.
The CMD-P (Ctrl+P for us) script looks handy, but what would happen if we use the File > Print option instead of a keyboard shortcut? Presumably this would bypass the script!?!
