Vehicle turning paths
Dexie
Does anyone have the expertise to translate this programming into a form that can be used in Vectorworks. It is written to recreate the vehicle tracking /turning circles of vehicle within a development. It has been written for AutoCAD but something similar would be great in VW.
I imagine it would be quite a challenge and I look forward to any interesting comments.
BuildVehicle.LSP
Copyright 2006 Stephen Hitchcox
BuildVehicle.LSP draws vehicles for use by Tturn.lsp in AutoCAD.
This program is free software under the terms of the
GNU (GNU--acronym for Gnu's Not Unix--sounds like canoe)
General Public License as published by the Free Software Foundation,
version 2 of the License.
You can redistribute this software for any fee or no fee and/or
modify it in any way, but it and ANY MODIFICATIONS OR DERIVATIONS
continue to be governed by the license, which protects the perpetual availability of the software for free distribution and modification.
You CAN'T put this code into any proprietary package. Read the license.
If you improve this software, please make a revision submittal to the copyright owner at hdesign@ica.net
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License on the World Wide Web for more details.
OVERVIEW
BuildVehicle.LSP draws attributed blocks of vehicles that are required by Tturn.lsp, for approximating the paths of trucks as they drive.
GETTING STARTED
Load and run BuildVehicle. It will ask you for all of the parameters
for your vehicle, and draw a unique attributed block. You can build a library of vehicles for future use. BuildVehicle.lsp runs using "BV" or "BuildVehicle" from the command line. Axles should be the "centroid" of any group of multiple axles.
Data for turning angles and time to turn is for future use, so enter dummy data if you do not know it.
enter "N" for no trailer, but still give place holder data for the non-existent trailer. It will not be drawn.
The parameters are used to build a scale block of the vehicle you are defining, which is made into a block.
You can change the attributes in the block if you make a mistake, but the block itself does not change size (it is not parametric).
If you make a new block with the same name as an existing one, it will overwrite the old one, or perhaps fail. If this happens, erase all errant blocks, and purge the old block from the drawing file.
Remember, there is almost no error correction in this program. If you enter impossible geometry, the program will happily draw it. Please report issues and requested functionality to the author.
REFERENCE
Vehicle dimensions (ft) Min. Outside Min. Inside
Vehicle Width WB1 WB2 Rad Rad. (check)
P (passenger) 7 11 24.0 13.8
SU (single truck) 8.5 20 42.0 27.8
BUS 8.5 25 42.0 24.4
WB-40 8.5 13 27 40.0 18.9
WB-50 8.5 20 30 45.0 19.2
Development Notes:
1) implement better error correction
2) collect and share correctly dimensioned standard vehicles
3) revise to not require data for non-existent trailers, and to allow multiple trailers
4) revise to draw tires centred on the tire paths
C:BV short form call for (C:BUILDVEHICLE)
(DEFUN
C:BV
(C:BUILDVEHICLE)
(DEFUN
C:BUILDVEHICLE
(SETQ VEHNAME (GETSTRING T "\nEnter Name of Vehicle: "))
(SETQ INPUTTEST "f")
(WHILE (= INPUTTEST "f")
(PROGN
(SETQ
VEHUNITS
(GETSTRING "\nEnter Units Type 'M'etric or 'I'mperial: ")
(SETQ VEHUNITS (STRCASE VEHUNITS))
(IF (OR (= VEHUNITS "M") (= VEHUNITS "I"))
(SETQ INPUTTEST "T")
(PRINC
"\nSorry, this value cannot be used, please try again"
(SETQ
STARTDRAWPOINT
(GETPOINT "\nPick midpoint of front bumper: ")
(SETQ
VEHBODYLENGTH
(GETDIST STARTDRAWPOINT "\nLength of Vehicle: ")
(SETQ
VEHWIDTH
(* 2 (GETDIST STARTDRAWPOINT "\nHalf width of Vehicle: "))
;; Record VEHWIDTH
;; MAKEATTRIBUTE usage: (MakeAttribute InsPoint InsAngle Tag Value AttribLayer AttPrompt TextSize)
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT PI (/ VEHWIDTH 15))
90.0
"VEHWIDTH"
(RTOS VEHWIDTH)
"AttributeLayer"
"Vehicle width"
(/ VEHWIDTH 15)
(SETQ VEHBLOCKLIST (SSADD (ENTLAST)))
;; Record VEHBODYLENGTH
(MAKEATTRIBUTE
(POLAR
(POLAR STARTDRAWPOINT (* 1.5 PI) (* VEHWIDTH 0.55))
0.0
(/ VEHBODYLENGTH 2)
0.0
"VEHBODYLENGTH"
(RTOS VEHBODYLENGTH)
"AttributeLayer"
"Vehicle body length"
(/ VEHWIDTH 15)
(SSADD (ENTLAST) VEHBLOCKLIST)
;; Draw BODY
(DRAWBOX
(POLAR STARTDRAWPOINT (* 1.5 PI) (/ VEHWIDTH 2))
VEHBODYLENGTH
VEHWIDTH
"truckbody"
(SETQ
VEHFRONTHANG
(GETREAL "\nEnter front overhang from Bumper to Axle: ")
;; Record front axle offset
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT 0.0 (/ VEHFRONTHANG 2))
0.0
"VEHFRONTHANG"
(RTOS VEHFRONTHANG)
"AttributeLayer"
"Vehicle front overhang"
(/ VEHWIDTH 15)
(SETQ
VEHWHEELBASE
(GETREAL "\nEnter vehicle wheelbase: ")
(IF (< VEHBODYLENGTH (+ VEHFRONTHANG VEHWHEELBASE))
(PRINC
"\nCaution, Vehicle Length is shorter than sum of Front Overhang and Wheelbase. Errors could occur."
;; Record rear axle location
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT 0.0 (+ VEHFRONTHANG VEHWHEELBASE))
90
"VEHWHEELBASE"
(RTOS VEHWHEELBASE)
"AttributeLayer"
"Vehicle wheelbase"
(/ VEHWIDTH 15)
;; Record name of vehicle
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG (/ VEHWHEELBASE 2))
0.0
"VEHNAME"
VEHNAME
"AttributeLayer"
"Vehicle name"
(/ VEHWIDTH 10)
;; Record units of vehicle
(MAKEATTRIBUTE
(POLAR
(POLAR STARTDRAWPOINT (* 1.5 PI) (* VEHWIDTH 0.25))
0.0
(/ VEHBODYLENGTH 2)
0.0
"VEHUNITS"
VEHUNITS
"AttributeLayer"
"Vehicle units (Metric or Imperial)"
(/ VEHWIDTH 15)
;;; VehSteerLock isn't currently functional.
;;; (setq VehSteerLock 0.0)
(SETQ VEHSTEERLOCK (GETREAL "\nEnter vehicle Steering Lock Angle: "))
;; Record vehicle Steering Lock Angle
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT 0.0 (/ VEHFRONTHANG 3))
90.0
"VEHSTEERLOCK"
(RTOS VEHSTEERLOCK)
"AttributeLayer"
"Vehhicle steering lock angle"
(/ VEHWIDTH 15)
;;; VEHSTEERLOCKTIME isn't currently functional.
;;; (setq VehSteerLockTime 0.0)
(SETQ
VEHSTEERLOCKTIME
(GETREAL "\nEnter vehicle steering lock time: ")
;; Record vehicle steer lock time
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT 0.0 (* 2 (/ VEHFRONTHANG 3)))
90.0
"VEHSTEERLOCKTIME"
(RTOS VEHSTEERLOCKTIME)
"AttributeLayer"
"Vehicle steer lock time"
(/ VEHWIDTH 15)
(SETQ
VEHWHEELWIDTH
(GETREAL
"\nEnter maximum axle width to outside of wheels: "
;; Record wheel width
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT 0.0 VEHFRONTHANG)
90.0
"VEHWHEELWIDTH"
(RTOS VEHWHEELWIDTH)
"AttributeLayer"
"Vehicle wheel width"
(/ VEHWIDTH 15)
;; Draw tires
(SETQ WHEELWIDTH (/ VEHWIDTH 10))
(SETQ WHEELLENGTH (/ VEHBODYLENGTH 10))
;; DRAW FRONT LEFT wheel
(SETQ
WHEELFLSTARTX
(+ (CAR STARTDRAWPOINT)
(- VEHFRONTHANG (/ WHEELLENGTH 2))
(SETQ WHEELFLSTARTY (- (CADR STARTDRAWPOINT) (/ VEHWHEELWIDTH 2)))
(DRAWBOX
(LIST WHEELFLSTARTX WHEELFLSTARTY)
WHEELLENGTH
WHEELWIDTH
"truckbody"
;; Draw front right wheel
(SETQ
WHEELFRSTARTX
(SETQ
WHEELFRSTARTY
(+ (CADR STARTDRAWPOINT)
(- (/ VEHWHEELWIDTH 2) WHEELWIDTH)
(DRAWBOX
(LIST WHEELFRSTARTX WHEELFRSTARTY)
WHEELLENGTH
WHEELWIDTH
"truckbody"
;; Draw rear left wheel
(SETQ
WHEELRLSTARTX
VEHWHEELBASE
(SETQ WHEELRLSTARTY (- (CADR STARTDRAWPOINT) (/ VEHWHEELWIDTH 2)))
(DRAWBOX
(LIST WHEELRLSTARTX WHEELRLSTARTY)
WHEELLENGTH
WHEELWIDTH
"truckbody"
;; Draw rear right wheel
(SETQ
WHEELRRSTARTX
VEHWHEELBASE
(SETQ
WHEELRRSTARTY
(DRAWBOX
(LIST WHEELRRSTARTX WHEELRRSTARTY)
WHEELLENGTH
WHEELWIDTH
"truckbody"
(SETQ
VEHREARHITCH
(GETREAL
"\nEnter distance from rear axle to hitch (forward is NEGATIVE): "
;;Draw hitch
(SETQ
CIRCLELIST
(LIST
(CONS 0 "CIRCLE")
(CONS 100 "AcDbEntity")
(CONS 8 "truckbody")
(CONS 100 "AcDbCircle")
(CONS 40 (/ VEHWIDTH 10))
(CONS
10
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG VEHWHEELBASE VEHREARHITCH)
(ENTMAKE CIRCLELIST)
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
90.0
"VEHREARHITCH"
(RTOS VEHREARHITCH)
"AttributeLayer"
"Vehicle rear hitch location (forward is NEGATIVE): "
(/ VEHWIDTH 15)
;; End of main vehicle entry
;; Start trailer entry
(INITGET 1 "Yes No")
(SETQ
TRAILHAVE
(GETKWORD
"\nDoes unit have a trailer? Yes/No: "
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG VEHWHEELBASE (* VEHREARHITCH 0.5))
90.0
"TRAILHAVE"
TRAILHAVE
"AttributeLayer"
"Does unit have a trailer"
(/ VEHWIDTH 15)
(COND
((= TRAILHAVE "Yes")
;; Vehicle articulation angle not functional
;; (setq VehArtAngle 20.0)
(SETQ VEHARTANGLE
(GETREAL "\nEnter vehicle articulation angle: ")
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG VEHWHEELBASE (* VEHREARHITCH 1.5))
90.0
"VEHARTANGLE"
(RTOS VEHARTANGLE)
"AttributeLayer"
"Vehicle articulation angle"
(/ VEHWIDTH 15)
(SETQ TRAILNAME (GETSTRING "\nEnter name of trailer: "))
(PROGN
(SETQ
TRAILUNITS
(SETQ TRAILUNITS (STRCASE TRAILUNITS))
(IF (OR (= TRAILUNITS "M") (= TRAILUNITS "I"))
(PRINC
"\nSorry, this value cannot be used, please try again."
(SETQ
TRAILERHITCHTOWHEEL
(GETREAL
"\nEnter Distance from Hitch to Trailer Wheel: "
(SETQ
TRAILERWHEELWIDTH
(GETREAL "\nEnter width of Trailer Wheels: ")
(SETQ
TRAILERFRONTHANG
(GETREAL
"\nEnter Distance from Hitch to Front of Trailer: "
(SETQ
TRAILERBODYLENGTH
(GETREAL "\nEnter Overall Trailer Length: ")
(SETQ TRAILERWIDTH (GETREAL "\nEnter Trailer Width: "))
;; Record trailer Length
(MAKEATTRIBUTE
(POLAR
(POLAR STARTDRAWPOINT (* 1.5 PI) (* TRAILERWIDTH 0.55))
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
(/ TRAILERBODYLENGTH 2)
0.0
"TRAILERBODYLENGTH"
(RTOS TRAILERBODYLENGTH)
"AttributeLayer"
"Trailer body length"
(/ VEHWIDTH 15)
;; Record trailer name
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
0.0
"TRAILNAME"
TRAILNAME
"AttributeLayer"
"Trailer name"
(/ VEHWIDTH 10)
;; Record trailer units
(MAKEATTRIBUTE
(POLAR
(POLAR STARTDRAWPOINT (* 1.5 PI) (* TRAILERWIDTH 0.25))
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
0.0
"TRAILUNITS"
TRAILUNITS
"AttributeLayer"
"Trailer units"
(/ VEHWIDTH 15)
;; Record trailerfronthang
(MAKEATTRIBUTE
(POLAR
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
(- VEHREARHITCH (/ TRAILERFRONTHANG 2))
0.0
"TRAILERFRONTHANG"
(RTOS TRAILERFRONTHANG)
"AttributeLayer"
"Trailer front overhang"
(/ VEHWIDTH 15)
;; Record trailer to wheel length
(MAKEATTRIBUTE
(POLAR
(POLAR STARTDRAWPOINT (* 0.5 PI) (* TRAILERWIDTH 0.55))
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
0.0
"TRAILERHITCHTOWHEEL"
(RTOS TRAILERHITCHTOWHEEL)
"AttributeLayer"
"Trailer hitch to wheel length"
(/ VEHWIDTH 15)
;; Record trailer width
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
(- TRAILERBODYLENGTH TRAILERFRONTHANG)
90.0
"TRAILERWIDTH"
(RTOS TRAILERWIDTH)
"AttributeLayer"
"Trailer width"
(/ VEHWIDTH 15)
;; Record trailer wheel width
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
TRAILERHITCHTOWHEEL
90.0
"TRAILERWHEELWIDTH"
(RTOS TRAILERWHEELWIDTH)
"AttributeLayer"
"Trailer wheels width (to outside)"
(/ VEHWIDTH 15)
;; Draw trailer
(DRAWBOX
(POLAR
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
(- VEHREARHITCH TRAILERFRONTHANG)
(* 1.5 PI)
(/ TRAILERWIDTH 2)
TRAILERBODYLENGTH
TRAILERWIDTH
"trailerbody"
;; Draw rear left trailer tire
(SETQ
WHEELRLSTARTX
(- (+ (CAR STARTDRAWPOINT)
VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
TRAILERHITCHTOWHEEL
(/ WHEELLENGTH 2)
(SETQ WHEELRLSTARTY
(- (CADR STARTDRAWPOINT) (/ TRAILERWHEELWIDTH 2))
(DRAWBOX
WHEELLENGTH
WHEELWIDTH
"trailerbody"
;; Draw rear right trailer tire
(SETQ
WHEELRRSTARTX
VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
TRAILERHITCHTOWHEEL
(/ WHEELLENGTH 2)
(SETQ
WHEELRRSTARTY
(- (/ TRAILERWHEELWIDTH 2) WHEELWIDTH)
(DRAWBOX
WHEELLENGTH
WHEELWIDTH
"trailerbody"
;;(makeblock VehBlockList StartDrawPoint (strcat "VEHICLELIB" VEHNAME))
;;makes a block without accessible attributes, needs fix
(COMMAND
"-block"
(STRCAT "VEHICLELIB" VEHNAME)
STARTDRAWPOINT
VEHBLOCKLIST
(COMMAND
"-insert"
STARTDRAWPOINT
(alert(princ "\nDefinitions complete. Move vehicle into initial position and run TURN to track path."))
(PRINC)
;;; End Buildvehicle |
;;;Start buildvehicle subfunctions
(DEFUN
DRAWBOX
(STARTPOINT XLENGTH YLENGTH BOXLAYER /)
(SETQ BOXPOLYLIST NIL)
(SETQ
BOXPOLYLIST
(LIST
(CONS 43 0.0)
(CONS 70 1)
;; closed pline if set
(CONS 90 4)
;; polyline length
(CONS 8 BOXLAYER)
;; layer name
(CONS 100 "AcDbPolyline")
(CONS 0 "LWPOLYLINE")
(SETQ
BOXPOLYLIST
(CONS
(CONS
10
STARTPOINT
BOXPOLYLIST
(SETQ
BOXPOLYLIST
(CONS
(CONS
10
(POLAR STARTPOINT 0.0 XLENGTH)
BOXPOLYLIST
(SETQ
BOXPOLYLIST
(CONS
(CONS
10
(POLAR (POLAR STARTPOINT 0.0 XLENGTH) (/ PI 2) YLENGTH)
BOXPOLYLIST
(SETQ
BOXPOLYLIST
(CONS
(CONS
10
(POLAR STARTPOINT (/ PI 2) YLENGTH)
BOXPOLYLIST
(SETQ BOXPOLYLIST (REVERSE BOXPOLYLIST))
(ENTMAKE BOXPOLYLIST)
(DEFUN
MAKEATTRIBUTE
(INSPOINT INSANGLE TAG VALUE ATTRIBLAYER ATTPROMPT TEXTSIZE)
(SETQ ATTRIBUTELIST NIL)
(SETQ
ATTRIBUTELIST
(LIST
(CONS 0 "ATTDEF")
(CONS 100 "AcDbText")
(CONS 100 "AcDbAttributeDefinition")
(CONS 1 VALUE)
(CONS 2 TAG)
(CONS 3 ATTPROMPT)
(CONS 8 ATTRIBLAYER)
(CONS 10 INSPOINT) ; not applicable insert point
(CONS 11 INSPOINT) ; this is the real insert point
(CONS 40 TEXTSIZE)
(CONS 50 (* (/ INSANGLE 360) (* 2 PI)))
(CONS 70 8)
(CONS 72 4)
(ENTMAKE ATTRIBUTELIST)
;;;(defun makeblock (sset baspoint name / i e en blocktype) ;;; faster and neater than command -block, but needs fix
;;;(if (not sset) (setq sset (ssadd)))
;;;(if (or (/= 'STR (type name)) (= "" name)) (setq name "*A"))
;;;(if (= (substr name 1 1) "*")
;;; (setq blocktype 1 name "*A")
;;; (setq blocktype 0)
;;; (setq blocktype 2) ;; added by srh
;;;(entmake (append
;;; '((0 . "BLOCK"))
;;; (list (cons 2 name))
;;; (list (cons 70 blocktype))
;;; (list (cons 10 baspoint))
;;;(setq i -1)
;;;(while (setq e (ssname sset (setq i (1+ i))))
;;; (cond
;;; ((/= 1 (cdr (assoc 66 (entget e))))
;;; (if (entget e) (progn
;;; (entmake (entget e '("*")))
;;; (entdel e)
;;; ((= 1 (cdr (assoc 66 (entget e))))
;;; (setq en e)
;;; (while (/= "SEQEND" (cdr (assoc 0 (entget en))))
;;; (setq en (entnext en))
;;; (entmake (entget en '("*")))
;;; (entdel e)
;;;(setq name (entmake '((0 . "ENDBLK"))))
;;;(if name (progn
;;; (entmake (append
;;; '((0 . "INSERT"))
;;;(if name (entlast) nil)
;;;(defun c:makeblock ()
;;;(makeblock (ssget) (getpoint "\nInsertionpoint: ") (getstring "\nName:
;;; TURN.LSP
;;; Copyright 2006 Thomas Gail Haws
;;; Copyright 2006 Stephen Hitchcox
;;; TURN.LSP draws vehicle turning paths in AutoCAD.
;;; This program is free software under the terms of the
;;; GNU (GNU--acronym for Gnu's Not Unix--sounds like canoe)
;;; General Public License as published by the Free Software Foundation,
;;; version 2 of the License.
;;; You can redistribute this software for any fee or no fee and/or
;;; modify it in any way, but it and ANY MODIFICATIONS OR DERIVATIONS
;;; continue to be governed by the license, which protects the perpetual
;;; availability of the software for free distribution and modification.
;;; You CAN'T put this code into any proprietary package. Read the license.
;;; If you improve this software, please make a revision submittal to the
;;; partial copyright owner at hawstom@sprintmail.com or see www.hawsedc.com.
;;; This program is distributed in the hope that it will be useful,
;;; but WITHOUT ANY WARRANTY; without even the implied warranty of
;;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
;;; GNU General Public License on the World Wide Web for more details.
;;; OVERVIEW
;;; TTURN.LSP draws a polyline along a theoretical rear wheel path
;;; as it follows the polyline front wheel path of a turning/weaving
;;; vehicle and also draws the body of the vehicle and a single trailer.
;;; While TTURN.LSP is theoretically accurate only for
;;; two-wheeled vehicles, its tested results correlate very well to
;;; published AASHTO turning templates, even for articulated vehicles.
;;; This version of TTURN.LSP has no default vehicle information. It requires
;;; use of attributed blocks made using the sister program "BuildVehicle".
;;; which contain all required information other than the path. Note that
;;; Tturn.lsp at this moment is at a beta level, and has no error correction,
;;; and does not check for minimum radius paths allowed by each vehicle. It
;;; also does not take into account speed, friction, slope, and other variables.
;;; Refer to commercially available programs if you really want a verified
;;; algorithm.
;;; GETTING STARTED
;;; At minimum, all TURN.LSP needs from you is a front left wheel path polyline
;;; and a BuildVehicle block. Try the following exercise.
;;; First, draw a good, long, polyline representing a front wheel path.
;;; For good looks, begin and end the path with plenty of straight length.
;;; then (just for convenience and clarity, not necessity) offset the
;;; polyline the vehicle width to create the other wheel path.
;;; Second, load and run BuildVehicle. It will ask you for all of the parameters
;;; for your vehicle, and draw a unique attributed block. You can build a library
;;; of vehicles for future use. BuildVehicle.lsp runs using "BV" or "BuildVehicle"
;;; from the command line.
;;; Third, load and run TTURN.LSP by dragging it into your drawing and typing "TTURN"
;;; or "TT". When prompted, select the BuildVehicle block of your choice, and then
;;; select the front wheel path very near the starting end,
;;; then pick the point representing the direction to the same side rear wheel.
;;; Tturn.lsp uses the dimensions of the vehicle block for calculations.
;;; Accept TURN.LSP's suggestions for a calculation step and plotting accuracy
;;; or enter your own.
;;; Turn draws several POINT objects, then erases them and draws the path of the
;;; rear wheel, along with the tractor and trailer bodies, as well as all other tire
;;; paths.
;;; REFERENCE
;;; Vehicle dimensions (ft) Min. Outside Min. Inside
;;; Vehicle Width WB1 WB2 Rad Rad. (check)
;;; P (passenger) 7 11 24.0 13.8
;;; SU (single truck) 8.5 20 42.0 27.8
;;; BUS 8.5 25 42.0 24.4
;;; WB-40 8.5 13 27 40.0 18.9
;;; WB-50 8.5 20 30 45.0 19.2
;;; DEVELOPMENT NOTES
;;; Added by Hitchcox: tractor and trailer bodies, trailer path, buildvehicle program.
;;; Added by Hitchcox: Vehicle defaults and overhang capabilities
;;; THEORY
;;; For each computation step, a vehicle wheel pair (front and back) is assumed
;;; to be traveling in a circle as though the steering wheel or articulating hinge
;;; were locked. The front and back wheels are circumscribing two concentric
;;; circles, with the line between back and front wheel always tangent to the
;;; inner circle being made by the back wheel, as shown:
;;; <= Counter-clockwise Travel
;;; ooo
;;; o o F0
;;; o /o
;;; o _ L/ o
;;; o / \/ o
;;; o B1 C B0 o
;;; o L/ \ _ / o
;;; o/ o
;;; F1 o o
;;; ooo
;;; => Counter-clockwise Travel
;;; The initial locations of the back and front wheels are known (B0 and F0), and the
;;; final location of the front wheel is known (F1).
;;; Then the turned angle F0|C|F1=B0|C|B1=2*atan{sin(alpha)/[2*L/S-cos(alpha)]}
;;; where
;;; S=the distance from F0 to F1
;;; L=the distance from B0 to F0, the wheelbase length
;;; alpha=angle F1|F0|B0
;;; REVISION HISTORY
;;; Date Programmer Revision
;;; 20070327 SH 1.1.2 Trailer plotting
;;; 20061213 TGH 1.1.1 Initial vehicle orientation from mandatory block selection instead of prompt.
;;; 20060324 SH 1.1.0 Added BUILDVEHICLE interface to allow overhang and sideswipe analysis.
;;; 20040507 TGH 1.0.1 Added osnap shutoff and restore.
;;; 20021025 TGH Replaced tracking equation with better algorithm. Removed plot point reduction algorithm.
;;; 20020627 TGH Added GETDISTX function to distribution file.
;;; 20020625 TGH Added capability to follow reverse drawn polylines.
(DEFUN
C:TURN
(/ ANGTRV DIRREAR1 DIRREAR2 DIRVEH1
DIRVEH2 DELTAL DSTTRV EMARK ENI
ES1 I LVEH OSMOLD PFRONT1
PFRONT2 PREAR1 PREAR2 TRACKLOCATION VEHICLEDATALIST
(SETVEHICLEDIMS)
(SETQ
ES1
(ENTSEL
"\nSelect starting end of polyline to track:"
;;TRACKLOCATION ("L")
;;(initget 1 "L M R")
;;(setq TRACKLOCATION (getkword "Is this track on the L eft, M iddle, or R ight of the front axle? (L or M or R) "))
(SETQ
PFRONT1
(OSNAP (CADR ES1) "endp")
LVEH
VEHWHEELBASE
;;(distance pfront1 prear1) ;This was the TURN.LSP method of getting wheelbase length
DIRVEH1
(CDR (ASSOC 50 (ENTGET VEHENTNAME)))
;;(ANGLE PFRONT1 PREAR1) ;This was the TURN.LSP method of getting initial angle
DIRTRAILER
DIRVEH1
DIRREAR1
DIRVEH1
;; Define step distance as 1/10 length of wheelbase
DELTAL
(/ LVEH 10.0)
DELTAL
(GETDISTX
PFRONT1
"\nCalculation step distance along front wheel path"
DELTAL
NIL
SS1
(SSADD)
OSMOLD
(GETVAR "osmode")
(SETQ
PREAR1
(POLAR PFRONT1 DIRVEH1 LVEH)
PPLT1
PREAR1
(SETVAR "osmode" 0)
;; Draw a point at first point of line
(COMMAND "._point" PFRONT1)
;; Add point to selection set
(SETQ
ENI (ENTLAST)
SS1 (SSADD ENI SS1)
;; Divide pline up by step distance
(COMMAND "._measure" ES1 DELTAL)
;; Build selection set of all points generated following first point
(WHILE (SETQ ENI (ENTNEXT ENI)) (SETQ SS1 (SSADD ENI SS1)))
(SETQ I (1- (SSLENGTH SS1)))
;; 20020625 Revision. See header.
;;Reverse the selection set if the pline is backwards
;;(if picked point is closer to last MEASURE command point than first)
(IF (<
(DISTANCE
(TRANS
;; the coordinates of the point to translate
(CDR (ASSOC 10 (ENTGET (SSNAME SS1 I))))
;; from pline coordinate system
(SSNAME SS1 I)
;; to user coordinate system
1
;; the picked point, which is in the user coordinate system
PFRONT1
(DISTANCE
(TRANS
(CDR (ASSOC 10 (ENTGET (SSNAME SS1 1))))
(SSNAME SS1 1)
1
PFRONT1
(WHILE (< 0 (SETQ I (1- I)))
(SETQ ENI (SSNAME SS1 I))
(SSDEL ENI SS1)
(SSADD ENI SS1)
;; End 20020625 Revision
;; Initial Travel Angle from Pick Points
(SETQ DIRVEHDRAW (ANGLE PREAR1 PFRONT1))
(SETQ
PATHSEGMENTS
(1- (SSLENGTH SS1))
(DRAWBODY)
(SETQ I 0)
;;_______Initiate Rear Left Path
(SETQ
REARLEFTTIREPATHLIST
(LIST
(CONS 43 0.0)
;;(cons 70 1) ;;; no 70 code, not a closed pline
(CONS 90 PATHSEGMENTS)
;; polyline length
(CONS 8 "RLTirePath")
(SETQ
(CONS
(CONS 10 PREAR1)
;;_______Complete Initiate Rear Left Path
;;_______Initiate Front Right Path
(SETQ
FRONTRIGHTTIREPATHLIST
(LIST
(CONS 43 0.0)
;; polyline length
(CONS 8 "FRTirePath")
(SETQ
(CONS
(CONS
10
(POLAR PFRONT1 (+ DIRVEH1 (/ PI 2)) VEHWHEELWIDTH)
;;prear1)
;;_______Complete Initiate Front Right Path
;;_______Initiate Rear Right Path
(SETQ
REARRIGHTTIREPATHLIST
(LIST
(CONS 43 0.0)
;; polyline length
(CONS 8 "RRTirePath")
(SETQ
(CONS
(CONS
10
(POLAR PREAR1 (+ DIRVEH1 (/ PI 2)) VEHWHEELWIDTH)
;;_______Complete Initiate Rear Right Path
;;_______Initate Hitch Path
(SETQ
HITCHPATHLIST
(LIST
(CONS 43 0.0)
;; polyline length
(CONS 8 "HitchPath")
(SETQ
HITCHPATHLIST
(CONS
(CONS
10
(POLAR PFRONT1 (- DIRVEH1 REARHITCHANG) REARHITCHDIST)
HITCHPATHLIST
;;_______Complete Initiate Hitch Path
;; Calculate rear path.
;; For every point on front wheel path,
;; calculate a point on rear wheel path
(WHILE (SETQ ENI (SSNAME SS1 (SETQ I (1+ I))))
(SETQ
;; set second point to the location of eni in the current UCS
PFRONT2
(TRANS (CDR (ASSOC 10 (ENTGET ENI))) ENI 1)
;; angle of travel this step
DIRTRV
(ANGLE PFRONT1 PFRONT2)
;; angle between angle of travel and angle of vehicle
ALPHA
(- DIRVEH1 DIRTRV)
;;Distance front wheels traveled this step
DSTTRV
(DISTANCE PFRONT1 PFRONT2)
;;Angle vehicle turned this step
ANGTRN
(* 2
(ATAN
(/ (SIN ALPHA) (- (/ (* 2 LVEH) DSTTRV) (COS ALPHA)))
;;Direction of vehicle at end of this step
DIRVEH2
(+ DIRVEH1 ANGTRN)
;;Location of rear wheel at end of this step
PREAR2
(POLAR PFRONT2 DIRVEH2 LVEH)
;;Direction the rear wheel traveled this step
DIRREAR2
(ANGLE PPLT1 PREAR2)
;;Save this step's variables
PFRONT1
PFRONT2
PREAR1
PREAR2
DIRVEH1
DIRVEH2
DIRREAR1
DIRREAR2
PPLT1
PREAR2
;;End saving
;;Insert block at 180 from direction of travel
(SETQ DIRVEHDRAW (+ PI DIRVEH2))
(DRAWBODY)
(SETQ
(CONS
(CONS 10 PREAR2)
(SETQ
(CONS
(CONS
10
(POLAR PFRONT1 (+ DIRVEH2 (/ PI 2)) VEHWHEELWIDTH)
(SETQ
(CONS
(CONS
10
(POLAR PREAR2 (+ DIRVEH2 (/ PI 2)) VEHWHEELWIDTH)
(SETQ
HITCHPATHLIST
(CONS
(CONS
10
(POLAR PFRONT2 (- DIRVEH2 REARHITCHANG) REARHITCHDIST)
HITCHPATHLIST
(SETQ REARLEFTTIREPATHLIST (REVERSE REARLEFTTIREPATHLIST))
(ENTMAKE REARLEFTTIREPATHLIST)
(SETQ FRONTRIGHTTIREPATHLIST (REVERSE FRONTRIGHTTIREPATHLIST))
(ENTMAKE FRONTRIGHTTIREPATHLIST)
(SETQ REARRIGHTTIREPATHLIST (REVERSE REARRIGHTTIREPATHLIST))
(ENTMAKE REARRIGHTTIREPATHLIST)
(SETQ HITCHPATHLIST (REVERSE HITCHPATHLIST))
(ENTMAKE HITCHPATHLIST)
(SETQ HITCHPATH (ENTLAST))
(IF (= TRAILHAVE "Yes")
(TRAILERPATH)
(PRINC "\nTrailer not Included, no trailer calculated.")
(SETVAR "osmode" OSMOLD)
(COMMAND "._erase" SS1 "")
(REDRAW)
(PROMPT
(STRCAT
"\nTURN version 1.1.2, Copyright © 2006 Thomas Gail Haws and Stephen Hitchcox"
"\nTURN comes with ABSOLUTELY NO WARRANTY."
"\nThis is free software, and you are welcome to modify and"
"\nredistribute it under the terms of the GNU General Public License."
"\nThe latest version of TURN is always available at www.hawsedc.com")
(PRINC)
;;; GETDISTX
;;; Copyright Thomas Gail Haws 2006
;;; Get a distance providing the current value or a vanilla default.
;;; Usage: (getdistx startingpoint promptstring currentvalue vanilladefault)
(DEFUN
GETDISTX
(STARTINGPOINT PROMPTSTRING CURRENTVALUE VANILLADEFAULT)
(SETQ
CURRENTVALUE
(COND
(CURRENTVALUE)
(VANILLADEFAULT)
(0.0)
(SETQ
CURRENTVALUE
(COND
((GETDIST
STARTINGPOINT
(STRCAT PROMPTSTRING " <" (RTOS CURRENTVALUE) ">: ")
(T
CURRENTVALUE
;;; CREATE_VAR
(DEFUN
CREATE_VAR
(PREFIX SUFFIX STRNG /)
(SET (READ (STRCAT PREFIX SUFFIX)) STRNG)
;;; SETVEHICLEDIMS
(DEFUN
SETVEHICLEDIMS
(SETQ VEHICLEDATALIST (VEHICLEDATAGET))
(SETQ VEHICLEDATALISTLEN (LENGTH VEHICLEDATALIST))
(SETQ DATACOUNT 0)
(WHILE (< DATACOUNT VEHICLEDATALISTLEN)
(PROGN
(SETQ VARNAME (CAR (NTH DATACOUNT VEHICLEDATALIST)))
(SETQ VARVALUE (CADR (NTH DATACOUNT VEHICLEDATALIST)))
;| No need to change to STRINGS just to change right back to REALS
(COND
((= (TYPE VARVALUE) REAL) (SETQ VARVALUE (RTOS VARVALUE)))
((= (TYPE VARVALUE) INT) (SETQ VARVALUE (ITOA VARVALUE)))
(SET (READ VARNAME) VARVALUE)
(SETQ DATACOUNT (+ 1 DATACOUNT))
(PRINC "\n done with loading and defining")
(setq vehName "TestVehicle")
(setq VehUnits "M")
(setq VehFronthang 1220.0)
(setq VehWheelbase 6100.0)
(setq VehWheelWidth 2000.0)
(setq VehBodyLength 9150.0)
(setq VehWidth 2440.0)
(setq VehRearHitch 2100.0)
(setq TrailerHitchToWheel 10000.0)
(setq TrailerWheelWidth 2000.0)
(setq TrailerFrontHang 1000.0)
(setq TrailerBodyLength 12000.0)
(setq TrailerWidth 2440.0)
;; reform all numeric variables to reals, to ensure all items are reals to avoid rounding
(FOREACH
VAR
'(VEHSTEERLOCK VEHSTEERLOCKTIME
VEHARTANGLE VEHFRONTHANG
VEHWHEELBASE VEHWHEELWIDTH
VEHBODYLENGTH VEHWIDTH
VEHREARHITCH TRAILERHITCHTOWHEEL
TRAILERWHEELWIDTH TRAILERFRONTHANG
TRAILERBODYLENGTH TRAILERWIDTH
(IF (= (TYPE (EVAL VAR)) 'STR)
(SET VAR (ATOF (EVAL VAR)))
(SETQ
FRONTLEFTBUMPANG
(ATAN
(/ (/ (- VEHWIDTH VEHWHEELWIDTH) 2)
VEHFRONTHANG
(SETQ
FRONTLEFTBUMPDIST
(SQRT
(+ (* (/ (- VEHWIDTH VEHWHEELWIDTH) 2)
(* VEHFRONTHANG VEHFRONTHANG)
(SETQ
FRONTRIGHTBUMPANG
(ATAN
(/ (- (/ (- VEHWIDTH VEHWHEELWIDTH) 2) VEHWIDTH)
VEHFRONTHANG
(SETQ
FRONTRIGHTBUMPDIST
(SQRT
(+ (* (- VEHWIDTH (/ (- VEHWIDTH VEHWHEELWIDTH) 2))
(SETQ
REARLEFTBUMPANG
(+ (ATAN
(- VEHFRONTHANG VEHBODYLENGTH)
PI
(SETQ
REARLEFTBUMPDIST
(SQRT
(* (- VEHFRONTHANG VEHBODYLENGTH)
(SETQ
REARRIGHTBUMPANG
(+ (ATAN
PI
(SETQ
REARRIGHTBUMPDIST
(SQRT
(SETQ
REARHITCHANG
(ATAN
(/ (/ VEHWHEELWIDTH 2)
(- 0 (+ VEHWHEELBASE VEHREARHITCH))
(SETQ
REARHITCHDIST
(SQRT
(+ (* (/ VEHWHEELWIDTH 2)
(/ VEHWHEELWIDTH 2)
(* (+ VEHWHEELBASE VEHREARHITCH)
(SETQ
FRONTLEFTTRAILERANG
(ATAN
(/ (/ TRAILERWIDTH 2)
TRAILERFRONTHANG
(SETQ
FRONTLEFTTRAILERDIST
(SQRT
(+ (* (/ TRAILERWIDTH 2)
(/ TRAILERWIDTH 2)
(* TRAILERFRONTHANG TRAILERFRONTHANG)
(SETQ
REARLEFTTRAILERANG
(+ (ATAN
(- TRAILERFRONTHANG TRAILERBODYLENGTH)
PI
(SETQ
REARLEFTTRAILERDIST
(SQRT
(/ TRAILERWIDTH 2)
(* (- TRAILERFRONTHANG TRAILERBODYLENGTH)
(DEFUN
DRAWBODY
(SETQ
TRUCKBODYPOLYLIST
(LIST
(CONS 43 0.0)
(CONS 70 1)
(CONS 90 4)
;; polyline length
(SETQ
TRUCKBODYPOLYLIST
(CONS
(CONS
10
(POLAR
PFRONT1
(+ FRONTLEFTBUMPANG DIRVEHDRAW)
FRONTLEFTBUMPDIST
TRUCKBODYPOLYLIST
(SETQ
TRUCKBODYPOLYLIST
(CONS
(CONS
10
(POLAR
PFRONT1
(+ FRONTRIGHTBUMPANG DIRVEHDRAW)
FRONTRIGHTBUMPDIST
TRUCKBODYPOLYLIST
(SETQ
TRUCKBODYPOLYLIST
(CONS
(CONS
10
(POLAR
PFRONT1
(+ REARRIGHTBUMPANG DIRVEHDRAW)
REARRIGHTBUMPDIST
TRUCKBODYPOLYLIST
(SETQ
TRUCKBODYPOLYLIST
(CONS
(CONS
10
(POLAR
PFRONT1
(+ REARLEFTBUMPANG DIRVEHDRAW)
REARLEFTBUMPDIST
TRUCKBODYPOLYLIST
(SETQ TRUCKBODYPOLYLIST (REVERSE TRUCKBODYPOLYLIST))
(ENTMAKE TRUCKBODYPOLYLIST)
(DEFUN
DRAWTRAILER
(SETQ TRAILERBODYPOLYLIST NIL)
(SETQ
TRAILERBODYPOLYLIST
(LIST
(CONS 43 0.0)
(CONS 70 1)
(CONS 90 4)
;; polyline length
(CONS 8 "trailerbody")
(SETQ
TRAILERBODYPOLYLIST
(CONS
(CONS
10
(POLAR
PFRONT1
(+ DIRVEHDRAW FRONTLEFTTRAILERANG)
TRAILERBODYPOLYLIST
(SETQ
TRAILERBODYPOLYLIST
(CONS
(CONS
10
(POLAR
PFRONT1
(- DIRVEHDRAW FRONTLEFTTRAILERANG)
TRAILERBODYPOLYLIST
(SETQ
TRAILERBODYPOLYLIST
(CONS
(CONS
10
(POLAR
PFRONT1
(- DIRVEHDRAW REARLEFTTRAILERANG)
REARLEFTTRAILERDIST
TRAILERBODYPOLYLIST
(SETQ
TRAILERBODYPOLYLIST
(CONS
(CONS
10
(POLAR
PFRONT1
(+ DIRVEHDRAW REARLEFTTRAILERANG)
REARLEFTTRAILERDIST
TRAILERBODYPOLYLIST
(SETQ TRAILERBODYPOLYLIST (REVERSE TRAILERBODYPOLYLIST))
(ENTMAKE TRAILERBODYPOLYLIST)
;;; Function TrailerPath
(DEFUN
TRAILERPATH
;; strip header stuff from trailerpointslist
(WHILE (/= (CAR (CAR HITCHPATHLIST)) 10)
(SETQ HITCHPATHLIST (CDR HITCHPATHLIST))
(SETQ HITCHPATHLISTCOUNT 0)
(SETQ PPLT1 (CDR (NTH 0 HITCHPATHLIST)))
(SETQ PFRONT1 PPLT1)
;; get first trailer point
(SETQ DIRVEH1 DIRTRAILER)
(SETQ LVEH TRAILERHITCHTOWHEEL)
(SETQ PREAR1 (POLAR PPLT1 DIRVEH1 LVEH))
(DRAWTRAILER)
;;_______Initiate Rear Left Trailer Path
(SETQ
REARLEFTTRAILERTIREPATHLIST
(LIST
(CONS 43 0.0)
;; polyline length
(CONS 8 "RLTrailerTirePath")
(SETQ
(CONS
(CONS
10
(POLAR
PREAR1
(SETQ
REARRIGHTTRAILERTIREPATHLIST
(LIST
(CONS 43 0.0)
;; polyline length
(CONS 8 "RRTrailerTirePath")
(SETQ
(CONS
(CONS
10
(POLAR
PREAR1
(- DIRVEH1 (/ PI 2))
(SETQ HITCHPATHLISTCOUNT (1+ HITCHPATHLISTCOUNT))
(WHILE (< HITCHPATHLISTCOUNT PATHSEGMENTS)
(SETQ
PFRONT2
(CDR (NTH HITCHPATHLISTCOUNT HITCHPATHLIST))
(SETQ
DIRTRV
(SETQ
ALPHA
(- DIRVEH1 DIRTRV)
(SETQ
DSTTRV
(SETQ
ANGTRN
(* 2
(ATAN
(SETQ
DIRVEH2
(+ DIRVEH1 ANGTRN)
(SETQ
PREAR2
(SETQ
PFRONT1
PFRONT2
(SETQ
PREAR1
PREAR2
(SETQ
DIRVEH1
DIRVEH2
(SETQ
DIRREAR2
(DRAWTRAILER)
(SETQ
(CONS
(CONS
10
(POLAR
PREAR1
(SETQ
(CONS
(CONS
10
(POLAR
PREAR1
(- DIRVEH2 (/ PI 2))
(SETQ
DIRREAR1
DIRREAR2
PPLT1
PREAR2
(DRAWTRAILER)
(SETQ
(REVERSE REARLEFTTRAILERTIREPATHLIST)
(ENTMAKE REARLEFTTRAILERTIREPATHLIST)
(SETQ
(REVERSE REARRIGHTTRAILERTIREPATHLIST)
(ENTMAKE REARRIGHTTRAILERTIREPATHLIST)
;; VEHICLEDATAGET gets the vehicle attributes from a BUILDVEHICLE
;; defined block.
;; Returns a list of vehicle properties.
(DEFUN
VEHICLEDATAGET
(/ CHANGEFROMDEFAULT
CONTINUELOAD ENTITYTYPE
TAG VALUE
VEHICLEDATALISTLEN VEHICLEBLOCKNAME
VEHICLEENTITYLIST
(SETQ VEHICLEDATALIST nil)
(SETQ VEHICLEBLOCKNAME nil)
(SETQ VEHICLEBLOCKNAME (CAR (ENTSEL "\nSelect Vehicle: ")))
(SETQ CHANGEFROMDEFAULT 0)
;;If a block was selected, get its data. Otherwise alert and fail.
(COND
(AND
VEHICLEBLOCKNAME
(SETQ VEHICLEENTITYLIST (ENTGET VEHICLEBLOCKNAME))
(SETQ ENTITYTYPE (CDR (ASSOC 0 VEHICLEENTITYLIST)))
(= ENTITYTYPE "INSERT")
;;Preload default vehicle
(progn
(SETQ
VEHICLEDATALIST
(LIST
(LIST "VEHENTNAME" VEHICLEBLOCKNAME)
(LIST "VEHNAME" "TestVehicle")
(LIST "VEHUNITS" "M")
(LIST "VEHSTEERLOCK" 0.0)
(LIST "VEHSTEERLOCKTIME" 0.0)
(LIST "VEHARTANGLE" 20.0)
(LIST "VEHFRONTHANG" 1220.0)
(LIST "VEHWHEELBASE" 6100.0)
(LIST "VEHWHEELWIDTH" 2000.0)
(LIST "VEHBODYLENGTH" 9150.0)
(LIST "VEHWIDTH" 2440.0)
(LIST "VEHREARHITCH" 2100.0)
(LIST "TRAILHAVE" "N")
(LIST "TRAILNAME" "TestVehicle")
(LIST "TRAILUNITS" "M")
(LIST "TRAILERHITCHTOWHEEL" 10000.0)
(LIST "TRAILERWHEELWIDTH" 2000.0)
(LIST "TRAILERFRONTHANG" 1000.0)
(LIST "TRAILERBODYLENGTH" 12000.0)
(LIST "TRAILERWIDTH" 2440.0)
(SETQ CONTINUELOAD "YES")
(WHILE (AND
(SETQ VEHICLEBLOCKNAME (ENTNEXT VEHICLEBLOCKNAME))
(= CONTINUELOAD "YES")
(COND
((= ENTITYTYPE "ATTRIB")
(progn
(SETQ VALUE (CDR (ASSOC 1 VEHICLEENTITYLIST)))
(SETQ TAG (CDR (ASSOC 2 VEHICLEENTITYLIST)))
;;subst values in list
;;if a value has been substituted (even with same value),
;;then increment ChangeFromDefault by one
(SETQ COUNT 0)
(WHILE (< COUNT VEHICLEDATALISTLEN)
(IF (= (CAR (NTH COUNT VEHICLEDATALIST)) TAG)
(PROGN
(SETQ OLDPAIR (NTH COUNT VEHICLEDATALIST))
(SETQ NEWPAIR (LIST TAG VALUE))
(SETQ
VEHICLEDATALIST
(SUBST NEWPAIR OLDPAIR VEHICLEDATALIST)
(SETQ CHANGEFROMDEFAULT (+ CHANGEFROMDEFAULT 1))
(SETQ COUNT (+ 1 COUNT))
((= ENTITYTYPE "SEQEND")
(SETQ CONTINUELOAD "NO")
) ;end progn
(T
(ALERT
(PRINC
"\n ENTITY SELECTED IS NOT A VALID BLOCK.\n\nRUN BUILDVEHICLE TO DEFINE A VEHICLE."
;;check if ChangeFromDefault matches required data list length. if not, then
;;report that not all data was found, and that some default values are being used
(COND
((= CHANGEFROMDEFAULT 0)
(ALERT
(PRINC
"\n NO DIMENSIONS OR DATA FOUND.\nPLEASE CHECK THAT SOURCE ENTITY IS VALID.\nDEFAULT VALUES WILL BE USED.\n\nRUN BUILDVEHICLE TO DEFINE A VEHICLE."
((= CHANGEFROMDEFAULT VEHICLEDATALISTLEN)
(PRINC
"\n ALL DIMENSIONS AND DATA FOUND, CUSTOMIZED VEHICLE HAS BEEN DEFINED"
(ALERT
(PRINC
"\n SOME DIMENSIONS OR DATA FOUND. PLEASE VERIFY THAT SOURCE BLOCK IS VALID. SOME DEFAULT VALUES WILL BE USED"
VEHICLEDATALIST
;;; Not yet used.
;;; Function TRAILINGPATH
;;; Returns a list of points that define a wheel path
;;; that trails a given front wheel path
;;; with the initial point of the trailing path as given
;;; Usage:
;;; (trailingpath
;;; frontpath The list of points that define the front path
;;; rearstart The first point on the trailing path
;;;Not yet used.
(DEFUN
TRAILINGPATH
(FRONTPATH REARSTART / I J)
(SETQ
I 0
PATHLISTLENGTH
(LENGTH FRONTPATH)
PREAR1
REARSTART
REARPATH
(LIST REARSTART)
(WHILE (< (SETQ I (1+ I)) PATHLISTLENGTH)
(SETQ
;; Set initial point to the previous point
PFRONT1
(NTH (1- I) FRONTPATH)
;; Set final point to current point
PFRONT2
(NTH I FRONTPATH)
;; Initial direction of vehicle
DIRVEH1
;; Angle of travel this step
DIRTRV
;; Angle between angle of travel and angle of vehicle
ALPHA
(- DIRVEH1 DIRTRV)
;; Distance front wheels traveled this step
DSTTRV
;; Angle vehicle turned this step
ANGTRN
(* 2
(ATAN
;; Direction of vehicle at end of this step
DIRVEH2
(+ DIRVEH1 ANGTRN)
;; Location of rear wheel at end of this step
PREAR2
;; Direction the rear wheel traveled this step
DIRREAR2
(ANGLE PREAR1 PREAR2)
;; Save this step's variables
PFRONT1
PFRONT2
PREAR1
PREAR2
DIRVEH1
DIRVEH2
DIRREAR1
DIRREAR2
REARPATH
(CONS PREAR2 REARPATH)
;;End saving
(REVERSE REARPATH)
I have monetarily supported those individuals that make me more productive with Vw, but there needs to be a single place where a person can quickly check what third party tools are available. Most of the tools that I have purchased were discovered by accident & sometimes the name of tool itself may not reflect its the full capability, for example Charles Chandler's "Land Planning" has an incredible number of tools that may go far beyond what a person may think would be included such as: "Close Gaps" tool & "Sewer Line Tool".
Petri & Miguel, when I come to the tech board with my inability to get Vw to do what I want, you guys have created tools to address the situation, but there doesn't seem to be any mechanism to make them commercially available. In my opinion it would be very beneficial for all users & Nemetschek, if they provided a central depository for third party tools. From what I understand third party tools for the major windows CAD programs is a very large & profitable business.
I don't have a problem with paying for work done by others. I have paid for bespoke scripting in the past and you get exactly what you require, but it is expensive.
If the is a mechanism for using a demo version or supplying a detailed description of what a PIO or script does before purchasing would be great.
Vehicle Turning Paths (script above) would I am sure be of use to many architects and urban designers to test layouts at an early stage, but development costs would be beyond what any individual would be prepared to pay.
Dexie,
I used to have some plug-ins available at VectorDepot. No-one bought them. Well, maybe they were not relevant, interesting, in demand etc. Whatever, the owner of VectorDepot told me that plug-ins just do not sell. VW users are not prepared to pay even the piddly USD 20 or 30 the authors want. (Well, actually: when selling through VectorDepot the author would get USD 10 or USD 15...)
But, hey: if you think that a Vehicle Turning Path tool would be of use & have commercial demand, I'm more than happy to sell the sole, world-wide distribution rights to you! There's an up-front payment and a royalty, of course.
This is a once in a lifetime opportunity for you to get rich and retire early!
I have to say that vector depot is a crap website, not the stuff on it (well not all of it), but the way it is built, organised, and kept up to date ( or not as the case may be ) if you sift through the crap there are occasionally a few things you would pay up to use, but because the website itself puts me off, i dont bother going there any more and look else where for my CAD needs. This could be one of the reasons it hasnt taken off.
Hey, to make it better: contact the owner, tell him how to improve the site, contribute good stuff. A few brilliant freebies (you being a true pro, that shouldn't be too hard) and then a series of truly seriously compelling items for the market place.
The reason why it hasn't taken off is, I believe, that the average VW user can't afford to pay even USD 20 for anything. Could it be that they are this desperate because they are not productive, relying only on NNA's stuff...
Anyway, elsewhere? Pray tell! I have a lot of stuff I could put on the market.
It is a pity, that there is not more open source vectorscript development going on. I am shure there are many excellent scripts and plugins developed by all you vectorscript enthusiasts out there. And I do have a few of my own.
Think of that: I could try to sell a hypothetical 20$ closed source tool and succeed to sell 100 copies. (100 copies should be considered an amazingly big success in the vectorworks marketplace) This makes me 2000$ at a considerable administrative overhead. Wow!
On the other hand I have wasted many times more than that trying to reinvent the wheel for my own plugins.
Of course everybody is reluctant to do the first step and opensource their development, or at least I am. Perhaps Nemetschek should do the first step and open some tools for the community to build upon. Unfortunately even Nemetschek fears that this would hinder their ability to maket the VW industry series.
So it seems most development either stays closed source or it does not even get off beyond rudimental, because there is no starting point from which to get going.
Edited by Thomas Wagensommerer
Petri
Send along a list of stuff that you are offering. You know, I am always desperate to make my road design life easier, but not willing to do my own scripting. Would rather spend what little time I have left over to play golf!
I have willing paid for 3rd party add-ons, but was very surprised to learn from Charles Chandler, Robert Mullin & Manuel Garcia de Paredes, who provide great tools, how few users had purchased their tools.
For me the VectorDepot site should first be sorted by Vw version (lots old & out dated items clutter the listing) & then if the product is commercial - the price, a detailed description & example of the tool's use would be very beneficial.
It's only a few years since they CLOSED their stuff!
Yes I know. I am shure those open tools got many developers started. But there is an important difference: Those tools were open, but not open source, so nobody felt obliged to contribute something back.
Now that those tools are really old and the commercial tools are already advanced enough, so that Nemetschek would not need to be worried to loose business, they could think about making them publicly available under an open source license. (Not that I personally would need that, because I have them anyway) I think it would greatly help new scripters and get something going.
In my opinion a healthy open source community would also be really profitable for Nemetschek. It would add more confidence for many customers, as they could always adopt an open source project, if they feel they dont have the right tools for very specialized needs.
On the other hand, I am not overly optimistic, because just releasing some code would not be enough. There needs to be ongoing commitment, which is a lot of work.
  • 5 weeks later...
I am with Bruce in the need for basic civil tools. While I aware of Charles's road tools and plan on buying in the near future, what tools do Robert Mullin & Manuel Garcia de Paredes have available.
I am a landscape architect with a large base of site planning clients. There is hardly a day that goes by that I do not wish for more tools and flexibility.
Raymond Mullin provides Reshaper Tool (http://www.siriussolutions.net/) which includes an azimuth mode that he added for me.
Manuel Garcia de Paredes (http: // www.vectorbits.com) has provided the following invaluable tools for me: Offset Paths, Center Page On Rectangle & Optimise Drawing.
Petri has shared a couple of his tools with me over the years, but I was not able to implement them into my workflow so I am still dependent on third party software.
Miguel A. Barrera seems to have developed some very useful tools for road design, but I have not been able to contact him for more information.
I am sure these individuals have numerous tools that would be very valuable to other users if a way could be found to suitably compensate them for their efforts.
