Constant Disk Access
Blue/White G3 300mHz 128mb installed OS9.1
1mb virtual memory on
Running VW9
After getting 10 to 12 objects on the sheet, every VW operation selected is followed by a disk access before the operation is initiated. Makes for very slow work.
Whatthehey?
Randy,
I've been gettin very slow performance since:
1. Upgrade to VW9/RW9
2. Install of 1gig ram (there's no virt.memory now...)
Other particulars:
I'm running OS/8.6, on a G4 400mhz.
The details: It seems the most simple of tasks get progressively more sticky as a work session progresses. Selecting, click & drag to move objects, grouping and ungrouping, cut & paste etc. all get less and less reponsive as work progresses. The last episode, this evening, I tried to move a grouping of objects and it wouldn't do it at all.
Saving seems to help a little bit, but not for very long. Likewise with restarting the system.
Tech support / phone, wasn't very helpful, except to say up grade to OS/9.0.4 might help. Have you (or anyone else) experienced similar symptoms?
Thanks!
